10-13-2022, 01:38 PM | #1 |
Dyno Shocker - Lost Power!!
So, it made 965 at 7000 a month ago with a 103 and 3" upper. We put a 112 and 2.75 on it this week and are shocked that it now gets to 850 at 5800 and rolls over badly.
99% of the HPT data looks good (except for KPa 11 is not right). Gained 3 lbs. boost, MAT is fine, spark and advance look good, etc., etc. Our first course of action is to replace the crimped exhaust pipe section today and redyno. Has anyone here had this happen to them? I'd bet shops such as KaTech have.
'20 ZL1 1LE A10,
10-13-2022, 01:41 PM | #2 | |
Post the dyno log.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
10-13-2022, 02:07 PM | #3 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
What does your fuel pressure and inj pw look like? Didn’t you do the LPE HPFP?
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
10-13-2022, 02:53 PM | #4 |
965 at 7k rpm isn't necessarily better than 850 at 5.8k rpm, was it much stronger at 5.8k rpm as well a month ago? The log or at least the entire dyno graph from both tests would be helpful. And yes, that wild correction was already discussed in another thread with you IIRC.
10-13-2022, 03:48 PM | #5 |
Drives: 21 ZL1 Join Date: Feb 2022
Lets see the log. Probably fuel pressure droping.
10-13-2022, 03:55 PM | #6 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
10-13-2022, 04:01 PM | #7 |
The flat portion of the exhaust isn't your problem.
Could be a number of things. I would guess it's fuel delivery related without seeing a log or even dyno graph. Shot in the dark guess is if you log the pid for high pressure fuel pump delivery angle you'll see its maxed at 130 degrees. |
10-13-2022, 04:05 PM | #8 | |
10-13-2022, 04:44 PM | #9 | |
https://www.camaro6.com/forums/showp...0&postcount=82
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“ |
10-13-2022, 05:17 PM | #10 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
I promise you it isn’t the crimp. I ran 8.40’s at over 162 MPH with it still there. We got rid of it and didn’t see any measurable change. It was just annoying me. Is the power higher at any point of the pull up to where it falls off?
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
10-13-2022, 05:24 PM | #11 | |
'20 ZL1 1LE A10,
10-13-2022, 05:56 PM | #12 |
I think its fuel related too. The extra 3psi of boost is demanding more fuel.
10-13-2022, 06:35 PM | #13 | |
Here's the log: Fuel rail press 2812 psi Low side 80 psi Inj pulse width 4.8 ms
'20 ZL1 1LE A10,
10-13-2022, 06:43 PM | #14 |
More data
'20 ZL1 1LE A10,
