10-02-2022, 10:35 AM | #1 |
How many hours to do this work?
1. Swapping my 103mm for a 112mm with new couplings, etc., and
2. Swapping my 3.00" upper for a 2.75, along with new belt. Dyno/tune not incl.
'20 ZL1 1LE A10,
10-02-2022, 12:57 PM | #2 |
1 lol…
10-02-2022, 01:34 PM | #3 |
'20 ZL1 1LE A10,
10-02-2022, 01:47 PM | #4 |
I was only half kidding. I usually leave most of the heavy lifting to my local shop so that things come out right. Things like a pulley swap and 103-to-112 TB swap I did myself and they didn’t take long. Swapping the blower pulley is probably 20 minutes. The TB swap took me a bit longer since I had to order a different silicone coupler for the Rotofab Big Gulp and an adapter for my Whipple since the 112 is not smooth fit it lol. But that was another 20-30 minutes of actual work once I had the parts lined up.
10-02-2022, 07:02 PM | #5 | |
Having FUN in the SUN...
For an experienced shop... my guess is 90 minutes but may bill for a 2 or 3 hour minimum... DIY... maybe 1/2 day depending on your tool level and experience.
10-07-2022, 02:49 PM | #6 |
3 hours to install 112 throttle body, adapter plate, upper pulley, measure and new belt, and remove/repair driver's canard.
'20 ZL1 1LE A10,
10-07-2022, 03:11 PM | #7 | |
112mm snouts require the EVAP solenoid to be relocated on Camaros which takes a bit more work. |
10-07-2022, 03:18 PM | #8 |
Yea, his rate is high, but 3 hours seems right.
'20 ZL1 1LE A10,
10-07-2022, 03:30 PM | #9 |
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
What’s the hourly rate there? Our Deere dealers are charging up to $200 per hour now.
24 2SS 1LE, Riptide Blue, A10, PDR. Picked up 11/5/23, 560 miles.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
10-07-2022, 03:32 PM | #10 |
$180
Every serviceman and tradesman here charges at least $150
'20 ZL1 1LE A10,
10-07-2022, 03:35 PM | #11 |
It seems high because we aren’t used to paying those rates, but that’s the new normal. It makes DIY look real good.
10-07-2022, 03:36 PM | #12 | |
What has KaTech found for 1000 hp motors?
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 10-09-2022 at 01:17 PM. |
10-10-2022, 12:30 PM | #13 |
