09-15-2022, 01:19 PM | #1 |
Drives: 2019 Camaro SS Riverside Blue Join Date: Sep 2020
Additional cooling with Magnuson 2650 build
Back in Dec. 2021, I made a huge purchase from Jannetty Racing in CT. Ted and Kris specifically were wonderful to work with, big shout out to them once again for helping me with my build. 2019 2SS with A10 trans, went from fully stock to JRE 700 whp terminator package and beyond, 100% assembled by myself and in my garage in about 6 weeks. Ted was super responsive and had me all remote tuned and ready to rip in around 2 weeks. The car is an absolute beast to drive now, I've daily driven it for around 4k miles and I love it even more!
My question is about the heat, which is now a larger factor being SC, and I'm wondering has anyone creatively come up with ways to tackle it in general. During the summer months of 100° temps, I'm seeing IAT/IAT2 temps quickly and easily climb to 140, 150, 160, and sometimes beyond. Mostly when in stop and go traffic of course, but even on the highways at 50-55mph they won't calm down much below 130-140. Also aggravated to some degree with the IAT temp (should be right after the CAI?), which won't cool off much of the time because I can't open the throttle past about 5% without losing traction on the street. Terrible problem to have, I know. LOL The Maggie intercooler is large and fully capable, however I went to the drag strip recently and sat in the staging line for what seemed like forever before making a couple runs that night. 90+ deg. temps, and IATs would both get to 165-170+ before I was up for a 1/4 mile run. Out of desperation while waiting in line, I would set my fan and coolant pump to run using the Aeroforce gauge @ 19% (which is max setting available), but that did very little to help prior to race time. I'm thinking of either adding a Lingenfelter 2.5gal aux. tank, and/or installing a custom fan assembly in front of the IC unit up front. Has anyone attempted something like this, outside of the typical interchiller setup? I'm not interested in tapping into the A/C unit and going that route, and also I'm aware of the typical trunk mounted ice tanks available as well. Just looking for alternate ways to fight the heat aside from moving to the north pole. I'd love to hear ideas, positive or negative or whatever, especially from those creative engineering types out there. The heat soak is insane, and I'm even wondering how to extract heat from the engine bay when I park in my garage! Seems as if my poor RotoFab Big Gulp is just getting heat soaked as well, and can't even function remotely as a CAI. Any help or suggestions would be great, as I'm beyond tired of searching for ideas and need to calm my extreme OCD here. |
09-15-2022, 05:12 PM | #2 | |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
The real solution (outside of an IC), is to add more fluid capacity to the cooling system. You can do a non-trunk tank option and it'll help some, but they are typically under the hood or close to the source of the heat. As a frame of reference, with a 6 gallon trunk tank (no ice just water) and upgraded pump, I cruise around at a max of 30 degrees above ambient. At the drag strip on a 95 degree day, I will end the pass at ambient starting with minimal ice in the tank and running bottom 8's. If it's iced down really good and I'm not waiting in line long, it'll be a couple degrees under ambient.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
09-15-2022, 05:33 PM | #3 | |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
09-15-2022, 05:44 PM | #4 | |
The temps you referenced are way higher than I’ve seen with the 2650 in any scenario other than sitting still with the car running for a long period of time. A setup like I’m referencing going wide open throttle on a roll in 70* would be in the low-upper 90* area. No ice needed.
09-15-2022, 05:58 PM | #5 |
I believe my Rhodes tank uses a Rule 3700 Pump
'20 ZL1 1LE A10,
09-15-2022, 06:01 PM | #6 |
There are a couple options out now I believe. At the time, Stewart was proven in many cars and more readily available. Relatively speaking, the stock pump is junk.
09-15-2022, 06:21 PM | #7 | |
09-15-2022, 06:32 PM | #8 |
I assume the aftermarket pumps push a lot more volume. I have read that the coolant can't be pushed too fast through the HE or it won't have time to pull the heat away. So, your Stewart is in place of the stock intercooler pump?
09-15-2022, 06:37 PM | #9 | |
09-15-2022, 06:45 PM | #10 |
Yes, it is the only pump in line. I’ve never heard of such a concern from anyone with proven cars. In fact, a benefit of removing the HX’s is that it allows water to move quicker through the entire system. The longer it sits, the hotter it’ll get and more useless it’ll become. The issue for a heavy use street car in that case is there is nothing extracting heat from the water. It’s no issue for casual driving where the car is moving more than stopping and going, or running down a drag strip.
09-15-2022, 06:56 PM | #11 | |
09-15-2022, 07:07 PM | #12 |
Casual driving is left up to interpretation obviously. The longest I’ve driven it like this is 30 minutes. MAT temps sitting still will easily get up into the 150’s while moving it’ll get back down into the 120-130* area. I assume eventually it would get hotter, but for my style of casual driving it’s a non-issue. But again, would never recommend it if the primary goal of the car wasn’t drag racing. The car has ran an 8.39 with literally no ice in the tank and just mild temp water. It’s best to date with more ice is 8.37. Lots more variables come into play with that stat, but I like debunking the belief that ice is always required with ice tanks. Especially when doing comparisons to other forms of cooling that I won’t name.
09-15-2022, 07:07 PM | #13 |
Your trunk is at say 70 and your blower is at say... much higher. The biggest benefit can be seen when put ice in the tank, turn on the tank pump and make a hit. Eventually the water and the tank heats up that's agreed
'20 ZL1 1LE A10,
09-15-2022, 07:11 PM | #14 |
What happens when your trunk is 100*+, which even in your neck of the woods is gonna happen in the summer. Out here where I live, my trunk will be hotter than that.
