Old 07-14-2022, 01:04 PM   #1
pablo0526
Drives: 19 CAMARO SS
Lightbulb Throttle body upgrade
Hello, i have been running an lt2 manifold with some bolt ons for some time and wondering if an upgraded Throttle body would make any difference if any to be worth it or if i should just port the stock one.
pablo0526 is offline   Reply With Quote
Old 07-14-2022, 01:29 PM   #2
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
LT2 maxes out at 95mm. So that is the biggest you can go.
But if you are using a stock TB which is 87mm it will make a difference, however I am not sure if the LT2 needs to be ported to take the 95mm?
Someone else will chime in to confirm if that is the case as I am not to sure.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
FlukeSS is offline   Reply With Quote
Old 07-14-2022, 06:28 PM   #3
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
The LT2 intake needs to be ported to take a 95 mm TB. You also need to buy the straight thru (95 mm to 95 mm ) adaptor to utilize the different 95 MM TB bolt pattern to the 87 MM TB bolt pattern on the intake manifold.
lt4camaro is offline   Reply With Quote
