Old 04-19-2022, 07:51 PM   #1
badstorm48
Drives: 2021 camaro lt1
Lt2 intake manifold
Hey everyone. So I installed the lt2 intake manifold on my Camaro today. When I went to connect the maf extension. On one side it clicked in right away. The other side it seems no matter how hard I tried to get it to click it just wouldn’t. Was wondering if anyone else had a similar issue and what did you do to fix it? I just pushed it down as far as I could and wrapped it with electrical tape. No check engine light came on so I believe it’s down enough to get a signal and it’s drives the same as the original intake manifold, but it still bothers me it not being connected all the way. Below is the extension I got which seems to be the one everyone recommends to get. Got it off of Amazon.
ICT Billet Wire Extension 24" LS Gen 4 MAP Manifold Absolute Pressure Sensor Connector LS3 OEM tooling, OEM Delphi (connector, lock, seals, and terminals WEMAP40-24
badstorm48 is offline   Reply With Quote
Old 04-19-2022, 08:15 PM   #2
CreeperRS
CreeperRS's Avatar
Drives: 20’ Chevrolet Camaro 2SS 1LE
Yes, when I was doing my homie’s LT2 intake, his ITC billet wire extension was not clicking at all. I had no problem on mine, must of been a bad batch. I had to file down the little tab that locks in. I don’t have a picture to show you, but you don’t have to file down too much, only like less than 1/16th of an inch.
CreeperRS is offline   Reply With Quote
Old 04-20-2022, 12:36 AM   #3
s346k
s346k's Avatar
Drives: like an old lady
i used the mid michigan harness, no issues.
2016+ camaro: everyone’s first car
s346k is offline   Reply With Quote
Old 04-20-2022, 12:43 AM   #4
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
I had the same issue with my GPI extension. I ran a zip tie around the entire connector and though the tab. No issues, but for sure not ideal. I called GPI and they said they had never heard of this issue and didn’t have a solution….
Ken
khcoaching is online now   Reply With Quote
Old 04-20-2022, 03:12 AM   #5
red6.2
Drives: 2010 camaro
it will click in... I thought at first they send me a defective one, but it will go in will enough force. You will hear in audible click.
red6.2 is offline   Reply With Quote
lt2, lt2 intake installation, lt2 intake manifold, maf sensor harness
