04-04-2022, 05:58 PM | #1 |
Drives: Slow Corolla Join Date: Apr 2021
Non 1LE V6 For Track Use
I’m trying to see if anyone has had experience with putting a non 1LE V6 on a road course or autocross course and how the car held up.
I’m thinking about going this route to save up front costs on the car with just GM’s lowering kit and larger brakes. What are other mods would be a must besides tires? Thanks
‘21 Satin Steel 1LT 1LE
Prior: '22 Camaro 1SS 1LE '90 Mustang LX '18 Volkswagen GTI |
04-10-2022, 11:16 PM | #2 |
Drives: Boost Coupe Stewie formerly '01 Z28 Join Date: Jan 2007
While not V6's, a number of us have happily campaigned 4 cylinder turbos at autocross and DE's. The cars are well balanced and can be enjoyable so long as you aren't looking for V8 power.
In terms of modifications, that may be dictated by how involved you want to get. For autocrossing, many of us run in the SCCA "Street" category. Essentially a "stock" class, you are allowed a very small number of modifications such as changing one sway bar (front or rear), a +1 or -1 wheel diameter change (width must remain the same, offset can be within 7mm) and finally a shock absorber change. If you want, give us more details about your car and we can chime in appropriately. |
04-11-2022, 01:28 AM | #3 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
You should be fine. There are plenty of i4 / v6 guys on the track. I wouldn't worry about trying to upgrade right away. If anything, the first mod should be upgrading to a dot 4 high temp brake fluid. If u want to upgrade pads, that works to. But before you go down the upgrading rabbit hole, get out there and take the beginner course and then see what needs improved.
04-11-2022, 02:13 PM | #4 |
Drives: 2020 Camaro ZL1 1 LE Join Date: Mar 2021
Those are really good V6 engines. Very powerful for their weight. There’s a guy in my region that has an RX-8 with the Camaro V6 swap with 6speed in it and it is very fast and reliable.
04-11-2022, 06:07 PM | #5 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
What AZIROC said. Get good brake fluid and pads on it and take it out.
You'll probably discover two things pretty quick: Any Alpha chassis car is a blast to drive on track. Your car has a LOT more capability than you thought it did. I assume it's a M6? I would guess the first issue you'll bump up against is keeping temps down. I don't think the V6's have cooling like the LT1/LT4 setups do. Just keep an eye on your oil temps if you do stay out for 20+ minutes per session.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
04-11-2022, 09:06 PM | #6 |
Drives: '23 1SS 1LE | '18 1LS V6 [sold] Join Date: Jul 2020
I drive a 1LS V6 base trim with 6-speed manual. To this day, I have done 9 track days and 4 autocrosses.
Key points of the V6 base chassis:
04-13-2022, 08:07 AM | #7 | |
I'm thinking about ordering a V6 with the GM lowering kit and either the 4 piston or 6 piston factory brakes. I had a 1LE but had to sell it and back off to a more practical daily driver for work. I'm hoping a V6 can take care of that.
04-13-2022, 08:10 AM | #8 | |
Would the factory brake upgrade on a V6 be plenty ? I had a 1LE for a while and got spoiled quickly for sure
04-13-2022, 08:16 AM | #9 | |
I'm looking to order a V6 as a solid daily driver, provided there's no constraints for months on end. Would you recommend the 4 piston brake upgrade that has the oil cooler? I see they have the 6 piston factory brake kit, but it doesn't let me select the oil cooler with that. I think the oil cooler is good insurance for a 25 minute session in the summer. The V6 1LE had the 4 piston brakes so I'm wondering if the 6 piston kit is overkill for the V6?
04-13-2022, 08:19 AM | #10 | |
If I order this, I was definitely thinking 20" wheels, brakes, and suspension kit from the factory. Been there already with doing that stuff myself with jackstands over the years - my knees are shot!
04-13-2022, 10:28 AM | #11 |
Just a heads up here: you can't add any post-production suspension kit and still run in Street (Stock) classes with SCCA. I'm sure any other sanctioning body would be similar. Even if the kit comes from GM, it's not a factory option but rather an aftermarket suspension kit. Same for the brakes.
Matt Miller
2020 SS 1LE |
04-13-2022, 12:16 PM | #12 | |
Even though this stuff is factory options, the upgrades aren't part of a "stock" class. Would it be possible to just be in a time trial class in autocross? Forgive the newb question - just used to doing HPDE. Paul
04-13-2022, 02:05 PM | #13 | |
Id assume they would, but I honestly don't know. Again, it would be a thing you would have to feel out while on the track. If anything, again id just swap out to a better brake fluid and maybe upgrade ur pads. Past that, id just drive and have fun. Stay in the lower (slower) group and just learn. Ask others if u can follow them to learn better lines. Hell, a good friend of mine is out there racing with us in his maxima. And he's keeping up just fine. Granted he is driving the ever loving shit out of it .. but he's doing it. Also look for what racing clubs are in your area and their rules. Some have very strick rules as far as what mods you can and can not do. For me there are 2 solid racing groups. 1, where I'm at, is more based on driver skill. The other is based on the cars performance. Since I still consider myself a novice, id probably be a liability if I was in the other race group because I'm in a zl1 and id be going up against guys MUCH fast than me. Where the group im in now, I could go up a "level and still be fine. |
04-13-2022, 03:00 PM | #14 | |||
Matt Miller
2020 SS 1LE |
