09-11-2017, 07:00 PM | #1 |
Drives: 2013 Join Date: Mar 2017
Broken Seat???
Have 2013 SS power seats..driver seat has problem, seems i broke something...seat is still attached to floor in 3 spots..the front two and the back inside one..the fourth one on the outside back by door is not attached..you can lift the corner of the seat up a few inches...right before it happened i heard a pop. did i maybe break a bolt or something like that...and how would be the best way to repair...thanks
09-11-2017, 09:13 PM | #2 |
Drives: 2013 Camaro SS Join Date: Oct 2016
There's only two bolts that hold the front seats in. The bolts are in the back the front hooks into the floor. I would remove the inside bolt and take the seat out. Once it's out you can inspect the seat carriage, the bolt and the bolt hole in the floor to try to determine what the issue. The removal of the seat is only a few minutes, the hardest part is unplugging the wire harness.
09-12-2017, 10:43 AM | #3 |
Drives: 2011 Camaro SS Convertible Join Date: Nov 2015
Take it to the dealer, unless you love playing with the harness.
