07-15-2017, 01:51 PM | #1 |
Drives: 2013 Join Date: Mar 2017
Purchased 2016 SS wheels...may have problem
my tires are on my 2013 SS are 275/40/20.. new ties are 275/35/20....tire rack tech support said could cause problems with braking and computer and speedometer...any ideas if there will be problems for me...thank you
07-15-2017, 02:28 PM | #2 |
Drives: Miss Con Ception Join Date: Aug 2016
Did you buy all 4? Because with the 245/40X20 fronts the 6th gen uses there won't be an issue.
AFAIK, the front and rear must be within 0.5" radius. You will be at 0.55" if you still have the 245/45 on the front. So you will be close. Bolt them on and find out. Your speedometer will read fast by 1.04%
2011 1SS/RS LS3 CGM
07-15-2017, 04:04 PM | #3 |
376 cubic inches of fun
The gen6 tires are too small in diameter for your gen5.
07-15-2017, 04:11 PM | #4 |
the tires on front are the same as i have now...its the back im worried about going from 275/40 to a 275/35
07-15-2017, 05:34 PM | #5 |
You only bought the rear wheels/tires?
2011 1SS/RS LS3 CGM
07-15-2017, 05:39 PM | #6 |
Drives: 2010 2SS/RS L99 IBM silver stipes Join Date: Dec 2015
What he is saying is you will be fine. For the Gen 6 they run and are set up to run that diameter. But the 5th Gen runs that diameter stock. So there shouldn't be a problem!?
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough.... |
07-15-2017, 05:40 PM | #7 |
OH. Sorry. You are worried about the tires........ Nevermind
Just bolt them on and see. If it acts funny or there is dummy lights, get different tires in back.
07-15-2017, 05:46 PM | #8 |
Evil Genius of Chevrolet
I run 305/35 on the rear with no problems
07-15-2017, 07:37 PM | #9 |
Drives: 2015 Chevy Camaro 2LS Join Date: May 2017
that is a 5mm sidewall diff. as stated above, should work great, but will be a +mph difference on speedo. need a math wiz here, but prolly only 2-3 mph faster than your speedo reads at 60mph. these things can be tuned into your ecu.
07-16-2017, 09:22 AM | #10 |
You need to have the same diameter tires on the front as on the rear or stabilitrak will show an error.
If all 4 tires are the same but smaller diameter than the originals, your speedo will be off. You can find tire diameters and an explanation of what the numbers in a tire size (example: 305/35) mean on the TireRack website. (Hint: 35 is not sidewall height in mm. It's a ratio.) |
07-16-2017, 10:02 AM | #11 |
thanks so much for in info, will put on next weekend and hope for the best
07-16-2017, 11:12 AM | #12 | |
It is not a 5mm sidewall difference. It is .54" or 13.7mm.
2011 1SS/RS LS3 CGM
Thread Tools | |
