03-13-2012, 02:33 PM | #1 |
Drives: 2017 SS 1LE Join Date: Sep 2011
10,000 Miles, is my clutch really starting to go??
I do a lot of city driving and the other day I took off agressively from a stoplight and noticed that my clutch slipped briefly then grabbed. At the next light the whole cabin was filled with burning clutch smell. Since then I've been really babying my take offs. Today I did a quick burnout and practiced my drag launch to get ready for the upcoming season (on private property), and the same thing happened. Brief slip, then go, then clutch smell. This will be my first season at the strip with this car and it is not normally driven very hard. Can it be that my clutch is already going out on me??
03-13-2012, 02:36 PM | #2 |
That's what it sounds like I am afraid to tell you..
03-13-2012, 02:36 PM | #3 |
aka Patrick
Check your fluid, @ 10,000 miles I hope it has been changed once or twice.
Dirty fluid can cause it to have issues. The Stock Clutch isn't that heafty of a clutch and doesn't take much to burn one out.. it is possible with spirited driving you'll finish the clutch off soon.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft |
03-13-2012, 02:42 PM | #4 |
The fluid has never been changed because frankly I've never heard of having to change clutch fluid early than 30,000 miles. 10,000 seems pretty short to me, but I'll be sure to go check it now.
03-13-2012, 03:21 PM | #5 |
Drives: 2011 Camaro SS/RS LS3 Join Date: Aug 2010
after seperating my brake/clutch fluid, I am changing it at every oil change. It is simple and easy and isn't a bunch of fluid.
Yeah, I'll get around to it...
03-13-2012, 03:27 PM | #6 |
aka Patrick
This
I've always heard and recommended every oil change to change clutch fluid.
03-13-2012, 04:24 PM | #7 | |
Sent from my SCH-I510 using Tapatalk
top 10 reason why real men drive stick. 10. A manual transmission is the ultimate in control 9. You can use automotive jargon and not sound like a total tool 8. You can't spell "manual" without "man" 7. Manual transmissions prove you can do more than one thing at a time 6. You can't drift in an auto 5. You can't pull fancy moves in an automatic 4. You get better fuel economy with a stick 3. You’ll never look like a chump if you can drive stick 2. Manual transmission cars are faster 1. Women like a guy who is good with his hands. |
03-13-2012, 07:22 PM | #8 | |
03-13-2012, 08:02 PM | #9 |
Drives: '69 SS Convertible Join Date: May 2009
http://www.camaro5.com/forums/showthread.php?t=34085
Add a separate resivoir. With this I change mine often...especially after drag racing. With as many times as i do it I'm sure it has already been flushed out. I probably need to start using DOT4. It might be too late for your current clutch though. Upgrade to an LS9 clutch next time but they aren't cheap.
-2010 Camaro 2SS | M6 | VR w/White Stripes | 1 3/4" KOOKS - 3" Magnaflow | LPE 3.91 gears | ADM tuned | Halltech w/ADM Scoop | Spohn/BMR Trailing Arm/Toe Rod | BC Coilovers| Pedders FE4 ZL1 swaybars | Cradle/Diff/Radius Rod bushings | VMax TB | Morimoto Projectors | MGW shifter | Red Calipers
Build Journal |
Thread Tools | |
Similar Threads | ||||
I want a new clutch, you too????? Sign here | tjbusa | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 370 | 08-10-2013 03:27 AM |
V6 w/ 12k miles clutch is out? | bnorwood1 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 17 | 08-12-2011 10:30 AM |
Celebrating 10,000 miles :) | Embalmer | 5th Gen Camaro SS LS LT General Discussions | 57 | 02-26-2010 08:48 PM |
Oil Change Ramp | mjlash22 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 17 | 01-21-2010 10:40 PM |
