Homepage Garage Wiki Register Social Groups Calendar Search Today's Posts Mark Forums Read
Old 11-07-2022, 07:08 AM   #71
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Curious if anyone else has a similar build that would share their RWHP, Boost numbers and E content?
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC
Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank
ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE
BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi
SOCAL.M6.ZLE is online now   Reply With Quote
Old 11-07-2022, 09:34 AM   #72
Katech_Mike
Drives: 2015 Camaro ZL1
Did you install a low side?(aux pump)
700-750RWHP SAE on E30. It will be hard out of lowside with much more than E30 if you don't have an aux pump.
If you install an aux pump you should be able to run E60 at minimum.
Katech_Mike is offline   Reply With Quote
Old 11-07-2022, 11:27 AM   #73
SOCAL.M6.ZLE
Not yet... gonna go through the remote tune with JRE as is, and see how bad the fueling looks. Speaking to Ted, he believes I will be running out of injector before the low side, so we will see... Stay tuned and thanks for all the help Mike! Can't wait to see the gains from your blower porting, and show off all the cool Katech goodies at the next cars and coffee!
Old 11-12-2022, 03:25 PM   #74
SOCAL.M6.ZLE
Hey guys I have an update... after weeks of work, a fair amount of blood, sweat and tears... several late nights and plenty of self doubt, today was the day to bring my baby back to life!
I sent the last few days installing the wiring harness, sensors and working through the hose management of my modified PCV system with new MM CC, and Katech Valve Covers. That took alot of patience.
Last night I used my DMS adapter to fill my HX system with 2 gallon fender tank, but damn it was messy. I bypassed the reply in order to get the system flowing, but after a while my funnel would back flow and soaked all of my new work :(
So i gave up on the adapter and opted for a 2" length of 3/4" hose and a large funnel so i could control when the funnel was open or closed. I think the new system took about 3 gallons total, and I kept bleeding and burping the fender tank under noting but fluid would come from the bleeder valve.
Filling the coolant was easier, and by 8am this morning it was time for TED to remote into my laptop, install the temp tune file and hope for the best...
I'll admit, although she did fire up within 5-6 seconds of cranking she ran like crap for 10-15 seconds then stalled. Tried again, even worse. Checked for codes, nothing... all looked good data wise, so we tried again and the idle held, and we were able to get some data. The "slightly" tuned idle already sounds killer, and I cant wait for her to run strong. I took her out for a quick 5-8 min shake down run in the neighborhood, and she ran fine... just a little jerky down low, but I know it will be better after tuning.
My only issue is that my fans never turned on so my IAT's were getting hot at idle and putting around at 15mph. Sent the data log to TED for feedback and instructions.
I will take some photos soon... here is a quick walk around for first "slightly" tuned audio porn!
Question for the pro's... how can I make sure my Tstat is opening and my HX / Coolant flow is working?
https://griffinart.smugmug.com/HIDDE.../i-3gGntRK/buy
Old 11-12-2022, 03:28 PM   #75
PowerDemon
PowerDemon's Avatar
Drives: Camaro ZL1, Golf GTI
Awesome! I’d love to see some pics of everything back in the car.
Can’t wait to see you get it dialed in. Congrats
’22 ZL1 Riverside Blue 6MT
’15 GTI Carbon Steel 6MT
PowerDemon is offline   Reply With Quote
Old 11-12-2022, 04:42 PM   #76
SOCAL.M6.ZLE
Ask and you shall receive...
WARNING: THE FOLLOWING IMAGES ARE NSFW AND MAY TRIGGER AN EMOTIONAL RESPONSE. THEY ARE NOT FOR CHILDREN AND MIGHT CAUSE YOU TO PURCHASE PARTS FOR YOUR CAR THAT THE WIFE WOULD NOT APPROVE.
VIEW AT YOUR OWN DISCRETION.
Old 11-12-2022, 05:29 PM   #77
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
What a sight
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 11-13-2022, 10:12 AM   #78
SOCAL.M6.ZLE
Originally Posted by arpad_m View Post
What a sight
Thank you sir... need to be patient now waiting for the back and forth process of remote tuning in order to work out the bugs. Hard not putting the front end back together and driving her today :(
The blower sounded so bad-ass during the shake down drive! The combo of porting, billet lid, and 20% OD makes it sound like a missile, even at low RPM... Can't wait to get her dialed in so i can take some video to share.
Old 11-13-2022, 10:15 AM   #79
SOCAL.M6.ZLE
This project has been so damn fun! But has been equally stressful and frustrating. I've found that even purchasing high quality parts, from quality vendors does not eliminate fitment issues, and with lack or poor of instructions with most parts doing this DIY requires alot of patience and research. Which has been a surprising element to the build.
Old 11-13-2022, 04:17 PM   #80
Sysopz
Sysopz's Avatar
Drives: 2018 ZLE M6, '15 CLS 63s AMG
Stunning, work of art imo!
2018 ZLE M6: Heads/Cam, Kong Stage X Port, Katech 103MM Throttle Body, Meth, Built by CSP, Flowmaster American Thunder, NITTO 345/30R19 NT555RII 811whp
2015 CLS 63s AMG MCT7: NGK plugs,BMC filters/spacers,Labworxs Development tune 644/766 (11.22 @ 127 1/4)
Sysopz is offline   Reply With Quote
Old 11-13-2022, 07:36 PM   #81
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Man that looks awesome. Congrats. Eager to see numbers.������
Scottyz is offline   Reply With Quote
Old 11-14-2022, 08:32 AM   #82
SOCAL.M6.ZLE
Thanks guys, me too... the remote tuning has begun, I would guess to have dyno numbers in a few weeks. I still don't have a "go to" shop in the area with a dynojet. May have to drive out of town.
I also just found an oil leak :(
I think it's my passenger side valve cover... gonna drive it again soon to try and confirm. Big downer :(
Old 11-14-2022, 10:56 PM   #83
Robster
Robster's Avatar
Drives: 2017 Camaro ZL1, 6M
Hot dang, that work looks beautiful. Nice job!
Robster is offline   Reply With Quote
Old 11-15-2022, 10:00 AM   #84
jjgi5150
Drives: 2022 ZL1 1LE
Hey SoCal….
That’s a beautiful job you’ve done with your machine. Good luck working out the final details. The ZLE is such an awesome car bone stock, I can only imagine how yours will run when you’re done.
JJ
2018 ZL1 1LE, NGM, Nav, PDR, born 11/22/17 SOLD
2022 ZLE, MH3, WCT, Nav, PDR, born 10/21-5/22!!!
2021 F-250 FX4
2023 Hyundai SF Calligraphy
jjgi5150 is offline   Reply With Quote
