Vararam
Old 11-05-2022, 12:41 PM   #1
steaksauce28
Drives: 2011 Camaro LS
Does this look like normal dirt/grime on the bottom of my L99
Just noticed this while cleaning it today. I'd imagine it's just what happens to a car after 12 years but wanted to get some other eyes on it for input. Haven't noticed any issues while driving.
steaksauce28 is offline   Reply With Quote
Old 11-07-2022, 07:45 AM   #2
LS1Formulation
Drives: '13 Camaro SS '98 Firebird Formula
Either you need a new oil pan gasket, or more likely, your timing cover seal is shot. It's hard to tell when the oil is that old, it migrates everywhere. I'd take degreaser and a power washer to that, clean it all off, then add some leak detecting dye to your oil and drive it a few hundred miles. Then get underneath with a blacklight and you'll likely see the source.
LS1Formulation is offline   Reply With Quote
Old 11-07-2022, 09:43 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Agreed with LS1. Looks like you have some seepage from some where and over time the road dirt and dust has covered it up looking like that. Plus the discoloration of the metal.
Old 11-09-2022, 03:22 PM   #4
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
Also looks like the metal brackett for your wire harness that goes under the front of oil pan isn’t secured .. the metal brackett that hold the red power wire
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.7 @133.9
Risingson05 is offline   Reply With Quote
