BeckyD @ James Martin Chevy
Old 11-03-2022, 02:00 PM   #1
Gus27
Drives: Camaro SS
1LE Spoiler help
Hello new to the forum here. I removed my factory trunk/spoiler to install a carbon fiber trunk/duckbill only to be left over with this epoxy. Any ideas on how to remove it?
https://ibb.co/wwkJhfp
https://ibb.co/j6CypKB
Gus27 is offline   Reply With Quote
Old 11-03-2022, 03:24 PM   #2
ZPirate
ZPirate's Avatar
Drives: 2023 Summit White Camaro ZL1 M6
Welcome to the forum.
You are likely going to need heat (blow dryer or heat gun) and some adhesive remover, like Goo Gone or 3M to get it off. I'd start with heat and see if you can peel it off. If you use a heat gun be careful not to get it too hot or you could damage the paint.
2023 Summit White ZL1 M6 (delivered 10/15/23)
2019 Dodge Durango R/T (daily driver)
2003 Nissan 350Z (modified)
2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold)
2009 BMW 135i (Sold)
ZPirate is offline   Reply With Quote
Old 11-03-2022, 06:55 PM   #3
22SS1LE
Drives: 2022 1SS 1LE 6M
i didnt think it would work but you need to get one of those eraser wheels.
I had to redo my winglets and had to use one to remove that adhesive
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22
New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17
8/24. IT HAS ARRIVED at the dealer
8/25- It is in the Garage
ACS ZL1 Sideskirts, 20% tint, CAI Intake
22SS1LE is offline   Reply With Quote
Old 11-03-2022, 07:37 PM   #4
Gus27
Drives: Camaro SS
I’ll give it a try, but this seems to be like almost like a resin, it’s not sticky to the touch it’s very hard and has no play when I try prying on it. I took it two a couple body shops and they said they need to grind it down and re spray the whole rear quarter panels if I wanted it done right only problem is the whole car has paint protection film and it’s brand new too. I rather not go that route.
Old 11-03-2022, 07:42 PM   #5
22SS1LE
yes i know. I cut it down as low as I could with a razor without touching paint and used the eraser wheel after, nothing else would remove it. Goo gone, tar remover..nothing
those body shops are either idiots or just want to get you to pay some money. use the eraser wheel and just do little at a time let it cool and keep going. I didnt do any damage to my paint
Old 11-03-2022, 07:45 PM   #6
Gus27
Drives: Camaro SS
Gotcha! Is there a specific eraser wheel brand/product you’d recommend? Thanks for your help!
Old 11-03-2022, 08:07 PM   #7
22SS1LE
i bought this one. was basically one of the first ones to pop up. they are all the same
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
Old 11-04-2022, 07:07 AM   #8
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I had one of my winglets FALL OFF going down the highway and then removed the other side and I never encountered what you're showing there but the winglets are dealer installed and someone could have mega glued yours as opposed to not doing a great job with mine. If they put some kind of expoxy cement you're body shop is probably the only option.
WhiteMale is online now   Reply With Quote
Old 11-04-2022, 08:51 AM   #9
22SS1LE
No that sealant on his car is what is supposed to be used when the winglets are installed.
It will come off with the eraser wheel. Took me about 20mins per side going slow and making sure nothing bad happened. Body shop isnt needed at all.
Old 11-08-2022, 12:55 PM   #10
Scargoes
Scargoes's Avatar
Drives: 2018 Hyper Blue 2SS 1LE
That looks like windshield urethane. It's a bitch to remove.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 11-09-2022, 03:43 PM   #11
Gus27
Drives: Camaro SS
I’m finally going to attempt to remove it tomorrow with the eraser wheel. Wish me luck lol I’ll post update pics
Old 11-09-2022, 06:06 PM   #12
22SS1LE
just go slow and dont heat up the paint to much. when you get it down to close to the paint. do like 30sec and then let it cool a bit and do it again till its all gone
Old 11-10-2022, 07:26 AM   #13
Melon
Melon's Avatar
Drives: '23 1LE, '18 Canyon, '87 325i
You may be able to use some hot water to help soften the glue.
If it's an epoxy, it will still be hard, so the eraser wheel is a good option. Just take your time and be patient, it will be worth it not to scar the paint.
Melon is offline   Reply With Quote
