09-26-2022, 12:35 PM | #43 |
We use a Fragola -6 bulkhead fitting.
Pulling the tank to install the bulkhead is still a 1/4 of the work it is to install an in-tank set up like a Fore twin or triple. |
09-26-2022, 05:24 PM | #44 | |
'20 ZL1 1LE A10,
10-26-2022, 10:37 AM | #45 | |
Having FUN in the SUN...
Hey Mike, Can you elaborate on why the in-tank pump is 3X the work for the AUX? Assuming you need to either drop the tank, or cut an access panel for either?
10-26-2022, 10:48 AM | #46 |
Fore setup is a return style system and designed for big power. So you’re adding pump controller, bigger fuel line, return line, regulator, Hobbs switch to activate pumps 2 & 3, etc. And they don’t give you brackets, heat shielding, etc. It was a healthy amount of work for the new Fore system to go in. If a shop bangs that out in a day it will not be a nice install lol…
10-26-2022, 11:41 AM | #47 | |
The DSX kits are pretty plug and play other than drilling the tank. Much quicker install. |
10-26-2022, 12:37 PM | #48 | |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
How much whp are they capable of on full E Mike? Thanks!
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror |
10-26-2022, 02:56 PM | #49 | |
10-26-2022, 07:51 PM | #50 | |
10-27-2022, 11:04 AM | #51 |
Old badass
Thanks Josh great insight. Mike I was referring to how much would the DSX supply?
10-27-2022, 12:36 PM | #52 |
