08-16-2022, 01:37 PM | #15 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
I did mine in my garage, there is a youtube video of the whole install start to finish out there somewhere, pretty easy process, spring compressors are a must!
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
08-16-2022, 02:34 PM | #16 | |
Drives: ZL1 Join Date: May 2020
You will need a full alignment afterwards because you will loose front camber settings when separating strut from the knuckle (you might be able to get close by using a screw with threaded hole). The back is going to be a bit of a struggle if you don't have access to a lift but given time and preparation it's doable with a floor jack and jack stands. Personally, if I have to do this again I would let an experience shop in aligning and adjusting camber do the all thing. My 2 cents. Also I am using Eibach springs for awhile now with no issues and quite pleased with the ride quality. |
08-16-2022, 05:23 PM | #17 |
Drives: 18 zl1 garnet red Join Date: Aug 2021
I appreciate the input from everyone . Looks like some solid feedback on the Eibach thus far.
IG - @zl1_will
2022 zl1 740hp / 730tq stolen 2018 zl1 Maggie - 2" headers - flex fuel - lowside fuel ssytem - +30 injectors - cordes ice tank - spl rear linkage arms |
08-17-2022, 08:48 AM | #18 | ||
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
Proof, if you have a minute to waste, lol. Don't ask, no clue why I bothered with a time lapse.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
08-17-2022, 11:15 AM | #19 | ||
Have you replaced the TTY bolts or re-used them? |
08-17-2022, 11:21 AM | #20 |
Drives: 2018 ZL-1 Join Date: Jan 2018
Always replace TTY bolts. They are torqued past the point of elastic deformation, and they do not snap back.
08-17-2022, 12:24 PM | #21 |
Drives: No Camaro :( Join Date: Apr 2013
08-17-2022, 01:10 PM | #22 |
Drives: 2022 ZL1 Join Date: Aug 2022
I'm curious about this topic as well, did any of you recalibrate your magride system after lowering?
08-17-2022, 02:56 PM | #23 | |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
And for other above comments, its possible Eibach has resolved this issue. A lot of what i found (which wasnt much) was older posts on here. I may give the Eibach a shot now based on everyones feedback |
08-17-2022, 02:59 PM | #24 |
I did not, according to my email to Eibach, they said it doesn't lower the car low enough to affect that magride for recalibration purposes.....so i haven't done it yet.
08-17-2022, 06:00 PM | #25 |
08-17-2022, 06:27 PM | #26 |
08-17-2022, 06:40 PM | #27 |
PKG4U
I see you trying to hide that wagon!
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S Mods after Warranty “Imma keep it stock” |
08-17-2022, 07:07 PM | #28 |
IG - @zl1_will
