08-26-2021, 11:19 PM | #1 | |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
DIY rally stripes. Save a buncha money.
Here's a simple design that looks good and anyone can do. I'm not a pro wrap guy, just a wrap DIY'er who wants to save money, have fun and change up my stripes frequently.
Materials and tools: 5' x 3' 3M 1080 Vinyl Wrap $38 3M Design Line Knifeless Tape $30 (you will use about $2 worth of it) Razor knife Felt squeegee Heat gun Infrared thermometer Tape measures Masking tape Car wash/detailing products to clean hood 1. Clean hood thoroughly including underside where the vinyl will be wrapped. Lay out a paper tape measure along the top hood edge. Measure 1.5" on each side of the hood center ridge and mark with masking tape. Lay a straight line of knifeless tape from the 1.5" marks down the hood. Measure along the way and make sure the tape is straight. Lay a line of knifeless tape on the ridges on each side of the hood. Measure to make sure the lines are even. 2. Cut a piece of vinyl 26" x 60". Save the smaller piece for the nose of the car. With the backing still on, lay the 26" x 60" vinyl piece on the hood and tape it down to the hood at the middle. 3. Fold the vinyl piece back halfway and peel off the backing. Pulling it off quicker is better than slower. Cut the paper backing with razor knife at the halfway point and remove. Don't panic if the vinyl sticks to itself or wrinkles. Be cool. It will come apart and wrinkles will come out with heat. Lay the vinyl gently across the hood. The vinyl won't stick until there's pressure from a squeegee. 4. Fold the other half back and do the same. [ 5. Now that the backing paper is off, apply the heat gun on high. Move the gun in circles until the surface reaches about 35-40 degrees Celsius. Let the vinyl cool a few moments then gently try to pull from the edges to get the big wrinkles out. You can lift the vinyl but be careful not to pull up the knifeless tape! If you pull it up, don't panic. Just peel the tape off the vinyl and put it back down. Apply the heat again to shrink the wrap down to the surface. Let the vinyl cool a few moments and pull gently from the edges so it looks tight. When it looks pretty good, start to squeegee from the middle to the edges. Don't lift your squeegee from the surface, move slowly and watch how the air channels out. Work the vinyl until you have all the air out. Don't make bubbles. Lift the edges if you need to and squeegee out any bubbles. If you get a crease, gently lift the edge, let go of the edge, apply a little heat, let it cool, pull the crease out. Never pull the vinyl while heating. **Sorry I forgot to take a picture of the wrap nice and tight before pulling the tape! 6. Pull the knifeless tape (watch 3M official video to learn about how to snap the tape.) Cut the top and bottom edges of the vinyl with razor knife so it will wrap about 1/2" around the edges. Apply heat gun and the squeegee to all the edges. 7. Use the leftover piece and the same techniques to cover the nose piece. Rally stripes for $40 (OK like $70 since you have to buy a full roll of tape) instead of $200!
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com Last edited by KirkH; 08-26-2021 at 11:34 PM. |
08-27-2021, 08:31 AM | #2 |
Very nice work, sir! Oh, wait, you're KirkH, no wonder it looks great!
Baby Blue
08-27-2021, 08:40 AM | #3 |
D3RPZILLA
Looks good! Every time I work with any kind of big piece of vinyl or any large sticky adhesive piece I swear wind immediately kicks in and everything flies (and sticks) together and ruins it OR random debris fly right into it and ruins it! Lol.
2021 Camaro ZL1 Satin Steel w/a10/PDR/CF/Red Belts/Navigation
Website: z1lla.com | YouTube: youtube.d3rpzilla.com YouTube Playlists: Performance Mods | Interior & Exterior Mods | Other Mods |
08-27-2021, 09:01 AM | #4 |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
WOW!!!
All freehand with just long pieces of vinyl. I've done some small fender decals but that was from a kit. I couldn't do what you did. I'd fudge that up in a hurry.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. Last edited by SSJ455; 08-27-2021 at 09:12 AM. |
08-27-2021, 02:23 PM | #5 | |||
Thank you sir! Quote:
Thanks! I've had it happen before. Most wrinkles and stuck things can be removed with a little heat. Quote:
Thanks, I hope this inspires someone to try it, because it is fun and looks cool.
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
08-28-2021, 04:40 AM | #6 |
Long hauler
I tried my hand at stripes for my original design, I did a little interior stuff on my brothers car but will use this next time I do it. Mine are slightly uneven but I didn’t use painters tape for whatever reason
I’m gonna try to do what this concept did but with white and whenever I can dump hours into it lol
08-28-2021, 12:16 PM | #7 | |
I think this design will be pretty easy. Just run your knifeless tape around the hood vent.
08-28-2021, 12:20 PM | #8 |
Here's a link for how to do fender hash marks.
https://www.camaro6.com/forums/showp...&postcount=273
09-01-2021, 10:17 AM | #9 | |
Drives: 2017 Chevrolet Camaro 1LT Coupe Join Date: Jul 2020
Nice
09-01-2021, 01:23 PM | #10 |
Long hauler
I found it from some of their concepts in like 2017, the cars color is Shock Green with vinyl and wheels. I’m just going after the vinyl but like Kirk said it should be easy (easier then my 2 hours per stripe on my original attempt lol)
07-29-2022, 04:02 PM | #11 |
I finally got around to doing this design. It was very easy. I like it.
Thread Tools | |
