06-30-2022, 09:40 AM | #1 |
Metallic whistling sound from left side...
Lately,
When I drive with my driver's side window opened, at lower speeds during hard acceleration I hear a high pitched whistling sound, but it sounds metallic in nature. Only does it during high acceleration. Almost sounds like it is coming from the exhaust. Just looking for ideas what this may be? No warning lights or anything.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
06-30-2022, 09:47 AM | #2 |
Drives: 19 CAMARO SS Join Date: Apr 2022
Any sound clips?
06-30-2022, 10:48 AM | #3 | |
Drives: 21 ZL1 Join Date: Feb 2022
If you need to take it in and see what the dealer will do, they will most likely replace the trans and it would probably happen again. I used to try to have the dealer chase down noises, but it usually ends badly for me or my car. So I have taken the approach to just drive the car until something actually breaks and the dumb dealer has no option but to acknowledge the failure and replace what has failed. Dealer service departments are just part swappers now and if you dont have a completely repeatable issue or clear cut failure, they will start shooting in the dark with parts and probably hurt your car in the end. |
06-30-2022, 11:19 AM | #4 |
I'll see if I can get one on the way home from work today, but the sound is pretty subtle so it may not come out on the video.
If the windows are closed I can't hear it, only when I have the window open did I happen to notice it.
07-01-2022, 07:36 AM | #5 |
I did a couple of mild pulls but did not hear the whistling, but thought I heard like a humming coming from the tranny, which means SATIN probably right, maybe normal sounds when the trans warms up.
