06-06-2019, 08:31 PM | #1 |
Drives: 2018 2ss 1le Join Date: Jan 2018
m6 crank pulley removal
thumbing through my eforce install guide and it says I need to remove starter to remove or install pulley...
can this be done without removing starter?
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned Last edited by biker2k; 06-06-2019 at 09:31 PM. |
06-07-2019, 06:38 AM | #2 |
Drives: 2017 Camaro 1SS M6 (SOLD) Join Date: Oct 2016
I did not remove starter when I did my Whipple. Since there was 2 of us, we left it in gear and stood on the brakes.
Heat the crank pulley bolt up before trying to remove it. Also our crank pulley tool, the thread stud was too short, ended up cutting the head off the stock bolt, threading the end for the tool and using that.
2017 1SS M6 Hyper Blue Metallic NPP, MMR 228 Z/28 replica wheels, Front: 20 x 9, Rear 20 x 11
Stock: 416hp/427tq, 12.21 @ 116.80 Modified 02/2019: Whipple SC w/ 3.500 pulley, LT4 fueling, NW 103 TB, Roto-Fab Big Gulp, Kooks 2" jet coated, full Borla ATAK exhaust, DSS axles, Gforce driveshaft. Tuned by EFX Tuning 688hp/632tq Best 1/4 to date: 10.705 @ 131.92 |
06-07-2019, 01:39 PM | #3 |
Drives: SS 6 speed of course Join Date: Jan 2016
with heat and the car in 6th gear the ebrake will hold the engine. The only puller to work is a Chrysler "installer" for harmonic dampers. free rental at your autozone.
https://www.autozone.com/loan-a-tool...ler/391370_0_0 Not the link does say "installer" but at least they finally change the description in puller...
06-07-2019, 03:25 PM | #4 |
I heated the bolt with my heat gun and used a loaner Chrysler puller from AutoZone. My stubby impact gun fit between the bolt and radiator and pulled the pulley right off with the car on stands and in neutral.
Baby Blue
