Roto-Fab
Old 03-18-2022, 09:20 PM   #1
SSVictor
Drives: 2010 Camaro 2SS
Help car won’t turn on after torque converter
I just got a 3000 stall converter installed and it was running fine when I got it after 1 hour of driving a engine light came on with abs and stability track and all my gauges also stopped working. My car wouldn’t shift out of 1st gear. Whenever I looked at the engine light on my SCT Tuner it said General Error 21000. Now my car won’t crank at all.
SSVictor is offline   Reply With Quote
Old 03-18-2022, 10:14 PM   #2
SSVictor
Update now when I try to crank it it acts like the battery is dead but all the gauges and everything work perfectly fine and the battery isn’t bad.
Old 03-18-2022, 10:24 PM   #3
HDRDTD
Are you still using the original battery ?
Old 03-18-2022, 10:27 PM   #4
SSVictor
Yes it’s the original battery
Old 03-19-2022, 06:29 AM   #5
joshnmn
2&THEHIT
joshnmn's Avatar
It's way past time for a new one
Old 03-19-2022, 07:53 AM   #6
Brutale arancia
Brutale arancia's Avatar
Drives: 2013 ZL1 Camaro
Reminds me of the time I let a wire get pinched between the block and bellhousing.
Brutale arancia is offline   Reply With Quote
Old 03-19-2022, 08:50 AM   #7
HDRDTD
Yes indeed it's time for a new battery regardless of how you have determined that your battery is 'ggod'.
With age and all the electronic stuff in our cars, when a battery ages, they cause all sorts of strange things happening.
Old 03-19-2022, 11:52 AM   #8
ADVMax
Sporting Foole
ADVMax's Avatar
Drives: 2010 Camaro SS
Have a load test done on the battery. Mine was still cranking the car fine but I had some of the “time for a battery” indicators. These cars will tell you when you need to freshen up the battery. A load test tells it all, mine went flat about the time he hit the switch on the load tester.
ADVMax is offline   Reply With Quote
Old 03-19-2022, 01:15 PM   #9
SSVictor
The battery is 70 percent charged
Old 03-19-2022, 01:23 PM   #10
SS376
SS376's Avatar
Drives: 2013 1SS LS3
I'd throw a new battery in. Even if that isn't the problem you need one anyway.
SS376 is offline   Reply With Quote
Old 03-19-2022, 02:46 PM   #11
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
For peace of mind, and most likely to fix your problems, get a new battery. Lots of members here with issues like yours and it solved their problems. Mine worked fine up until the day it died. Was at a buddies shop, had to move my car for a customer. Back out onto the street and installed it, I know I know, car would not start. Battery went completely flat. In my buddies 40 years of owning a shop he has never seen a battery take a sudden hit like that. Luckily I was at the shop, would not wanted to get stranded.
HOJO is offline   Reply With Quote
Old 03-19-2022, 04:24 PM   #12
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Battery voltage isn't a good indicator of a batteries capacity.
FasNuf is offline   Reply With Quote
Old 03-19-2022, 06:17 PM   #13
romcjr
romcjr's Avatar
Drives: Two 1984 Z28 / 2014 2SS/RS AGM L99
I'd listen to these guys about the new battery . I've only been here a short time , but I can't tell you how many threads I've seen with exactly the same symptoms and a new battery fixed it !!!
2014 2SS/RS AGM L99
CAI Intake
ELITE Catch Can
POWERSTOP Brakes (5/31/21)
romcjr is offline   Reply With Quote
Old 03-19-2022, 06:41 PM   #14
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Most likely the battery but a poor ground can cause this too. Regardless it's time for a new battery anyway.
TheFlyingBananaSS is offline   Reply With Quote
cam, engine light, help me, torque converter
