Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > Wheels | Tires | Suspension | Brakes
Old 11-16-2014, 12:52 AM   #1
Skullcandy
Skullcandy's Avatar
Drives: 2013 camaro 2ls
Brembo brake line bolt help
Hey guys, bought a set of brembo a for an upgrade from oem v6 brakes. Did rears no problem they came with everything already on so it was just simply bolt them on. The fronts needed the brake lines put on and the brake line brackets. This is were my night got bad. I went to go use the oem v6 brake line bolt (bolt with hole in the side to allow fluid into caliper) and it stripped out the first half of the caliper threads the line is supposed to connect to. I know this may have been a $200 screw up but I could really use some advice and help and info on where to find the correct bolt. Anything would help. Just want to fix my car. It's weird having better rear brakes than the fronts!:(
Skullcandy is offline   Reply With Quote
