06-08-2020, 02:30 PM | #1 |
Drives: 2013 C6Z06 Join Date: Nov 2016
BMR Swaybar Problems On Track (Solved)
After seeing @Badmojo post on a Facebook group that he had the same issue with his BMR Front Swaybar bushings while tracking his car, I decided I should make this post. I think I have a good solution finally, but I will tell the woes of the story.
First of all, I love the BMR swaybars and how they have transitioned the handling and body roll of my car on the track. My buddy @LS6Larry actually had this same issue before me and we had been trying to figure out a solution. His is the pic of the red bar, mine is the black hammertone bar. When tracking the car hard the BMR Front swaybar bushings can not handle the forces due to the much narrower bushing bracket and the bushings split after a few track days. I myself have split 2 of BMRs poly bushings and 1 GM truck rubber bushing that was a good fit. The rubber truck bushing lasted longer than the BMR poly, but it was still obviously a problem. The passenger bushing is always the one that split for us running CW tracks. (Not sure about @Badmojo) When comparing the BMR bushings and brackets to the stock pieces you will notice how wide the stock components are for better load distribution. I tried to remove the stock bushings from the bar, but they cannot be removed. Looking at the stock brackets I got the idea to modify the BMR bushings by cutting off the protruding edges and have them fit inside the recess of the stock brackets. Everything mounted up fine the first time, but when i went to the track i heard the dreaded rattle of the swaybar again and thought it failed. When i got home i found it didn't fail, but the bushing stop on the BMR bar was too large in diameter and was rubbing on the stock bracket. With some crude grinding work while the bar was still on the car I think I have effectively come up with a solution to the problem. I have a TNiA Wednesday if the rain holds off to test this again. Edited to clarify that I have never had a problem with the rear swaybar bushings. Last edited by TheRealJA105; 02-15-2021 at 07:35 AM. Reason: To clarify front bushing |
06-08-2020, 06:43 PM | #2 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Very surprised! I thought anything aftermarket was far superior to anything OEM. I am crashed!
On a serious note, curious to see what the solution is. |
06-08-2020, 07:52 PM | #3 |
Drives: 2017 SS 1LE Join Date: Aug 2017
I had this happen on my car, and called BMR about it. They have a different bushing and bracket now that's supposed to prevent this.
Just curious, how come the stock bushings couldn't be removed? I was looking at removing mine. |
06-09-2020, 09:06 AM | #4 | ||
Pretty sure my solution is going to work, but i did drive it last night and it was still rattling. So i think i need to actually remove the bar from the car and grind the entire circumference of the bushing shoulder down for clearance. Also another possible fix here that my friend was running (only for 2 trackdays so not proven yet as the normal bushings sometimes lasted 2 days) is another 32mm bushing set from Energy Suspension (who BMR uses) that uses a much smaller (less give) bushing and mount. I think it is this one https://energysuspension.com/energy-...mm?search=32mm With less bushing deflection the narrow bracket may be enough for the bushing to withstand the stresses. Now that i am on their site looking at it, depending on dimensions these Mustang bushings look like they are wider and could be a perfect fit for the stock Camaro brackets. https://energysuspension.com/energy-...ch=32mm&page=2 Quote:
Perhaps you can cut the stock bushings off of the swaybar without ruining them, but they aren't removable. They are either bonded or glued on. |
06-09-2020, 09:25 AM | #5 |
Did a little more digging and apparently BMR makes Delrin bushings for their Mustang bars. I bet that would also fix the problem, but the Mustang bars are 1-3/8" not 1-1/4" like the Camaro bars. Maybe they will make some for the Camaro and send them to me to test
06-09-2020, 10:53 AM | #6 |
hmm im going to have to check my afe power bushings next time my car is up in the air lol
06-09-2020, 11:41 AM | #7 | |
And i agree that OEM may offer a degree of compromise, which at times depends on a specific model. And hence some models absolutely do better with aftermarket parts for all out performance (such as your car). Yet many folks dont realize, that many aftermarket parts, even those sold widely by big names, are conceived in somebody's garage and "tested" by a few willing amateurs getting parts for free. To make matters worse, very few, if any, post about failures. So, good on you to post about your experience. Who cares if BMR "gets mad at you"?! They took your money, haven't they? I say, they should now refund it prompty and willingly, or offer you a free fix asap. Clearly, they must be well aware of this issue? Anyway, you may wish to try Strano perhaps? He's been making bars for a long time now. Dont know anything about his Camaro solutions per se, but his Vette bars have been solid and very popular based on feedback ive heard from many. He also tracks his car - as far as i recall. Mind you this was a few yrs back. One way or another, hope you'll get it fixed soon. Cheers! |
06-09-2020, 02:21 PM | #8 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
06-09-2020, 02:39 PM | #9 | |
Indeed he's not done anything regarding gen6 but he does carry Hotchkis and Pfadt bars and likely would have a constructive opinion about both vs the others. One nice thing about doing biz with him is: 1. He is an active driver and knows what works vs not either directly or indirectly. 2. He likes to do biz over the phone and doesnt mind sharing his views based on experience et al. Cheers! |
06-09-2020, 03:00 PM | #10 |
pfadt was sold to afe power btw the 6th gen bars are orange now not the gray and made by afe power pretty good stuff and 3 way adjustable !
06-09-2020, 03:07 PM | #11 | |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Especially a big name like BMR and for parts that will see performance driving duty. The number of performance shops out there these days that care just as much about the quality of the stuff they make as they do about the bottom line are becoming very rare indeed. It is for this reason I try to stay with OEM or OEM specced performance parts. Before I got my ZL1 1LE solid cradle bushings, I went back and forth between their lockout kit and while I know there have not been issues with those, I ultimately went with OEM performance parts for this very reason. I have had more headaches than I care to remember when dealing with the aftermarket, from spacers, to coilovers, to sway bars. It is hard to sway from the OEM performance parts (if they are offered for your particular vehicle) because they have to meet certain quality and have more R&D into them.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
06-10-2020, 07:50 AM | #12 | ||||
Well, i think my current setup actually is enough grinding. In kind of an admitted brain fart moment during this i realized when driving the car again last night that I haven't checked the end links tightness in awhile (especially considering the TSB for stock endlinks). Listening to the sounds it was making it also wasn't as bad of a rattle as when the bushing broke. So when i got the car on the lift at home to my delight the end links were loose! They are now tightened, but i didn't drive again, so i will find out today on the way to the track.
This reminds me to bring up another point. No fault to BMR on this as the bar is clearly much stiffer and this should be expected. The stock front endlinks will break with the bar under hard track use. Get aftermarket ones right away. Stock rears have been fine. Quote:
BMR is aware of the issue, I emailed them last year about it and they tried to sell me on the machined aluminum bracket of the same width with the same bushings. I didn't fall for that and told them i thought it wouldn't work because the bracket was still narrow. Well Badmojo proved they didn't work because he had them. All BMR would send me for free was a new set of originally supplied bushings and brackets, so at least I had extra bushings to play around with leading me to my own solution. I think if they would make the Delrin bushings for the Camaro bar that would be a winner with the machined brackets, but they are charging $200 extra for those in the Mustang fitment! Quote:
Before that he was talking about only changing the rear bar, but his driving style must be way different than mine because he wanted a softer rear bar. Hence why he was going to try the FEA rear. Quote:
06-10-2020, 08:50 AM | #13 |
Holy crap, hope Sam is alright! Thanks for posting the news. That must have been something completely catastrophic, or a major driver error? Just speculating of course. Would be good to find out for sure...
As one famous driver once said: "after a 3rd roll i completely lost control". Or something to this effect... |
06-10-2020, 09:05 AM | #14 |
As and aside, testing for reliability and longevity is one of the issues for aftermarket firms. They dont have free access to Milford afterall. Or hi tech to test for stress, etc. So i take any "track tested" claims with a large grain of salt. As in, tested by whom? How long? Where? With what results? Etc. Would not surprise me if mostly they subscribed a few willing volunteers gifted free kit to test things by the seat of their amateur pants. I know of such approaches first hand, but will protect the innocent as they gotta eat too (and i respect it). But that doesn't stop me from having my personal opinion of their products.
What gets me going is when aftermarket marketing types start spewing BS about OEM on BBs. Like a recent post about OEM 1le pads. |
