Old 09-06-2020, 06:52 AM   #1
Z28GTOSSMike
Drives: 2019 Camaro 1SS
Tracking non-1LE SS with 6 piston brake upgrade
For those that have installed the 6 piston front brakes on a SS and tracked their car, is the track deflector and splash shield that comes with the car (In the trunk) needed or is the new performance rotor shield that comes with the kit sufficient.
Z28GTOSSMike is offline   Reply With Quote
Old 09-06-2020, 07:15 AM   #2
cmfhsu
Drives: 2019 2SS 1LE
As I understand, you now have the exact same setup as a normal 1LE, aside from slotted rotors (and maybe different pads?), so you should be fine with the air deflector & rotor rock shield you have.
Worst case is you pick up a set of OE 1LE pads for your setup & be set.
cmfhsu is offline   Reply With Quote
Old 09-06-2020, 08:02 AM   #3
Z28GTOSSMike
Thanks for the reply. The kit came with Brembo pads, not sure if they are the OE 1LE pads as I didn't check the part number. I assumed they were the same.
Old 09-08-2020, 10:11 AM   #4
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Put the little splash shield and the track cooling deflectors on. You want all the cooling you can get.
TheRealJA105 is offline   Reply With Quote
Old 09-08-2020, 11:16 AM   #5
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i have the track deflector kit installed and a zzp bbk 6 piston kit on my car
