Go Back   CAMARO6 > Technical Camaro Topics > Cosmetic Maintenance - Wash, Wax, Detailing, Exterior Repairs
AWE Tuning
Old 07-25-2019, 02:54 PM   #1
Z28GTOSSMike
Drives: 2019 Camaro 1SS
Paint splatter removal
So I get ready to leave work and I notice what appears to be mud splattered on the rear of my car. Gently rub it with my finger only to find out it is white paint and does not rub right off. Looks like I drove through a puddle of wet paint. Any suggestions?
Z28GTOSSMike is offline   Reply With Quote
Old 07-25-2019, 02:56 PM   #2
lgarrison34
lgarrison34's Avatar
Drives: 2017 SS 1LE HBM, 2010 SS FBO/Cam
This should take it right off and can be used to smooth out any touch ups you may have to do too.
https://www.amazon.com/Langka-LANGKA.../dp/B000BAT622
lgarrison34 is offline   Reply With Quote
Old 07-25-2019, 03:00 PM   #3
GreatWhiteLT
Drives: 2016 Silver Ice Metallic SS
^ that stuff, or recently did a detail job on a range rover who ran over a bucket of paint and it exploded all over it and the person's GTR. If you use rubbing alcohol and are gentle with working it out, it'll come off. Worked fine on the range rover but I know the camaro paint is more delicate
GreatWhiteLT is offline   Reply With Quote
Old 07-25-2019, 03:34 PM   #4
KirkH
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD
1. IPA
2. Goof off
3. Compound and polish
4. Acetone (nail polish remover)
5. Wet sand
KirkH is offline   Reply With Quote
Old 07-25-2019, 07:32 PM   #5
Z28GTOSSMike
I used mineral spirits and lots of gentle rubbing but I think I got 99 percent of it off. Probably didn't do the paint any favors but I think it will be ok.
Old 07-25-2019, 07:48 PM   #6
ItsChristianInHD
ItsChristianInHD's Avatar
Drives: 2017 Camaro 2LT RS 3.6L
I got spray paint off with just some wax.
ItsChristianInHD is offline   Reply With Quote
Old 07-25-2019, 09:11 PM   #7
KirkH
Spray paint will come off with clay. Paint splatter from the road is thicker and tougher.
Old 07-26-2019, 06:27 AM   #8
Z28GTOSSMike
Got most all of it off with paint thinner (mineral spirits). Still some on the tire which I can live with and I can still see some on the very edge of the protective film but I am probably the only one that will notice it because I know it is there. Definitely didn't just wipe off, took a couple of hours and a lot of patience. Hopefully when I look at it again in bright light it isn't covered in a ton of micro scratches from all the rubbing.
Old 07-26-2019, 07:20 AM   #9
KirkH
The risk of using mineral spirits is the absorption of the solvent by the paint. Watch for the paint softening and swelling where you applied the mineral spirits.
Old 07-26-2019, 07:30 AM   #10
Z28GTOSSMike
I washed it off afterwards with soapy car wash. Hopefully I got it all off and there no problems with the paint. Geez, now I'm kinda worried. Hopefully I didn't screw it up.
Old 07-26-2019, 07:37 AM   #11
lgarrison34
You asked people what to use. They told you. You disregarded the advise and did your own thing. I'd be worried too.
Old 07-26-2019, 08:30 AM   #12
Z28GTOSSMike
You're absolutely right. I got in a hurry and used what I had that I thought would work. Hopefully I didn't screw it up. If I did then I have nobody to blame but myself.
Old 07-26-2019, 09:29 AM   #13
ItsChristianInHD
Ah, learn something new everyday.
Old 07-26-2019, 10:38 AM   #14
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
DuPont Prepsol works well too
Ryan B.
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
