AWE Tuning
Old 02-13-2023, 07:20 AM   #1
KL01
Drives: Chevy Camaro 2SS
D1X question.
Purchased a D1X procharger and wanted to know at what point you start seeing boost? I got it for the hp capability but will like to start boost around 4k rpms. For mods I got drop in piston and rods with lower compression, e85, btr intake full exhaust, stage 3 cam, headers, full exhaust, dsx aux fuel pump, lt4 injectors and getting hpfp.
KL01 is offline   Reply With Quote
Old 02-13-2023, 08:17 AM   #2
LT1ornothing
Drives: 2020 LT1 M6
Depending on what pulley you run, you should be seeing and feeling some boost around 3K rpm and it will gradually increase until redline.
[SBE] ECS NOVI 1500 supercharger, 2" Longtube headers, flex fuel, LT4 injectors, LT4 HPFP, baro breakout
Tune date and results to be determined
LT1ornothing is offline   Reply With Quote
Old 02-13-2023, 08:28 AM   #3
rcoe
rcoe's Avatar
Drives: 2016 Camaro SS
4k is were you will really start feeling it.
I have a very similar build but with a D1sc and she gets off the line pretty good but right around 4k is where the power really starts to hit all the way to redline.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Diamond Pistons/Manley Rods
BTR stage 3 cam - Circle D converter
American Racing headers - Borla S-type
rcoe is offline   Reply With Quote
Old 02-13-2023, 08:40 AM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
D1x doesn't build boost as fast as a D1SC. Generally speaking, with a 4" pulley you might see 3-4psi at 5k rpm and 13psi by 7k. Where the D1SC might see 5-6psi and 10psi up top. The D1x really starts to ramp up above 6k rpm.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 02-13-2023, 10:35 AM   #5
KL01
If that's true that would suck. Car redline at 6.5k. Only 500 rpms on full boost?
Old 02-13-2023, 11:59 AM   #6
LT1ornothing
Drives: 2020 LT1 M6
Your redline should be set higher than 6,500 rpm with a cam upgrade. If full boost at lower rpms was your goal, you should have gone with a positive displacement blower set up. D1X likes to be spun as King mentioned.
Old 02-13-2023, 12:11 PM   #7
KingLT1
KingLT1's Avatar
Yep... Centri's never really see "full" boost. They are a linear power adder that builds boost with RPM. So you cannot really look at peak boost like you do with PD or Turbo. You have to look at average boost. When Procharger sells you a "10 psi" pulley, that is peak. Your average boost will be more like 6-7psi.
If you are only going to spin the engine to 6500rpm I would simply pulley down your D1x so it makes boost quicker. Then you simply limit peak boost by reducing RPM.... Or rev it out higher. A stage 3 cam D1x setup should spin to 7200 rpm imo. A friend of mine put one on his car it wouldn't make shit for boost until 5k rpm. So he pullied it down and lowered shift point. But he only did that because it was on the stock bottom end.
Even the P1x doesn't really start making boost until like 4200 rpm. We gained 2-3psi from raising shift points from 6100 rpm to 6700rpm. Went from 7 psi to 9-10psi.
2016 NFG 1SS A8
Old 02-13-2023, 12:30 PM   #8
KL01
I would like the motor to spin more but the shop that installed the cam and piston/ rods kept it to stock rpm. I'll have to call procharger to see what pulley setup they recommend.
Old 02-13-2023, 02:22 PM   #9
Kerry
Drives: 2019 2SS Camaro
My experience so far with the new d1x
At 5k with a set point of the blower 55000 at 6500 rpm makes about 11.5 to 12 psi,at 5k. 4 k is making like 7 pds. I forgot the lower numbers off hand. It will make about 19 or so with a stock cam spinning that blower speed at 1000 ft elevation da about the same.. 8.25 lower 3.85 upper. 3.6 upper moves it up to about 13.5 14.5 at 5k and about 21 or 23 at 6500. It makes the car stupid fast.
I was following a car on 4 lane and I just touched the throttle a little to pass and almost hit the other car it accerlates so quick. Kinda scary for me. My wife dont like it at all.
Kerry is offline   Reply With Quote
Old 02-13-2023, 10:30 PM   #10
KL01
Thanks for the info. I went with a procharger just cause I don't need the instant boost, but in the other hand I don't want "boost lag". Coming from an NA car I am sure I will be impressed. I wonder how much higher I can take the rpms to safely.
Old 02-14-2023, 07:29 AM   #11
Kerry
good question. im wondering the same. I have shifted at 6650 alot.
Old 02-14-2023, 08:05 AM   #12
cjperformance
cjperformance's Avatar
Drives: 2017 Camaro SS 50th Anniversary
I think your bottom end and cam combo will support higher shift points and boost, but it looks like your high side fueling will be your limiting factor. I get 10.5 psi @ 6900 on a p1x w 4.13" pulley. Would like to pulley down a bit and drop the shift points a little.
I dont remember exact numbers but at around 5500 its 8-8.5 psi up to 10.5 psi at shift @ 6900 rpm. So avg boost around 9-9.5. Im thinking 10-10.5 psi avg boost might start hitting high side (LT4) fueling limits w/E50.
Im already pushing the high side fueling pretty far on my relatively tame setup. Would strongly consider aux port inj or bigger injectors.
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
cjperformance is offline   Reply With Quote
Old 02-14-2023, 08:10 AM   #13
KingLT1
KingLT1's Avatar
I think you will like the D1x. I would wait to see how it responds and adjust with pullies/rpm if need be. It's a very capable unit!!
2016 NFG 1SS A8
Old 02-14-2023, 12:46 PM   #14
Anom1LE
Anom1LE's Avatar
Drives: 18' 2SS 1LE, 94' Z28
I recently purchased a D1x and it's going on a SBE like your friends.
What pulley setup did he go with when he pullied it down? I am looking
to downsize the pulley for the earlier boost and 6500RPM shift point.
I will get the pistons/rods/heads/cam/extrasawce as I go along, but this
is where I am at currently and don't want the so called "boost lag".
2018 2SS 1LE -
D-1XH Procharged, Pray Tuned, Stainless Works, Anderson Composites, 13GFab, BC Forged & More
1994 Z28 - Direct Port Nitrous - Multi Magazine Feature Camaro Z28
Anom1LE is offline   Reply With Quote
