Roto-Fab
Old 11-10-2023, 07:01 AM   #673
romcjr
romcjr's Avatar
Drives: Two 1984 Z28 / 2014 2SS/RS AGM L99
Mine is at 82 k . Not driving so much since retired .
2014 2SS/RS AGM L99
CAI Intake
ELITE Catch Can
POWERSTOP Brakes (5/31/21)
romcjr is offline   Reply With Quote
Old 11-10-2023, 09:04 PM   #674
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Had to tighten up some of the bolts on my DSS axles. After replacing the boots I guess the bolts didn't get tightened down enough. A few started backing out which allowed a lot of grease to escape and get flung around.
So I had to clean up all that grease and torque all the bolts back down.
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 11-11-2023, 10:50 AM   #675
RupertPupkin
Drives: 2014 Camaro SS 1Le
Replaced the supercharger belt.
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 11-11-2023, 11:12 AM   #676
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
Before the Z06 takes over the QJ I figured I'd continue the maintenance on the 2LS. Changed the Diff fluid using AC Delco 75-90. It's nice that the Z/28 and 2LS take the same juice, I had a quart on the shelf.
ariZona28 is offline   Reply With Quote
Old 11-11-2023, 01:04 PM   #677
SlowLS1
SlowLS1's Avatar
Drives: 2010 Camaro SS , 2011 Colorado LS1
QuickJacks FTW
SlowLS1 is offline   Reply With Quote
Old 11-11-2023, 03:11 PM   #678
DRC69
DRC69's Avatar
Drives: 2011 RS 2LT
Quickjack NICE. Maybe for Xmas.
5000TL or 7000TL ?
Are you on Frame Extensions / Pinch-Weld Blocks??
DRC69 is offline   Reply With Quote
Old 11-11-2023, 04:55 PM   #679
SlowLS1
SlowLS1's Avatar
5000TL or 7000TL ?
I'm using the 5000TLX as is, and have lift pads installed on the car. Works great.
Old 11-12-2023, 09:05 AM   #680
Schpungus
Schpungus's Avatar
Drives: Aqua Blue '10 1LT/RS
Finally got around to installing my SJM Autoprod Halo Always On harness today. Only issue I ran into was that the wire heading to the fuse box was an inch too short - an easy fix with some wire I have in the toolbox & the old trusty soldering iron. Love the DRL/halo look & being able to keep the DRLs on when the headlights come on - just a shame that you lose the halos-only parking light function (but realistically I never used that anyway). All in all pretty pleased!
'10 Aqua Blue Metallic 1LT/RS
Schpungus is offline   Reply With Quote
Old 11-12-2023, 03:22 PM   #681
DRC69
DRC69's Avatar
Drives: 2011 RS 2LT
Thumbs up
Thank You for the help / info. I appreciate it.
Old 11-13-2023, 02:56 AM   #682
ariZona28
Give speed a chance
ariZona28's Avatar
5000TL or 7000TL ?
I've got the 5000 SLX. I have the ZL1 Addons magnetic pinch weld blocks that I use on both Camaros. Highly recommend.
Old 11-13-2023, 03:33 AM   #683
ariZona28
Give speed a chance
ariZona28's Avatar
Since I janked up the rear toe setting on my C5 Z06 I used the 2LS to perfect the toe plate procedure. My big problem was repeatability. No need to make adjustments to the Camaro, rear is toed in 1/16" and even tire wear. Now I need to correct the Z06. Glad I've got the QJ.
Old 11-13-2023, 09:41 AM   #684
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Good stuff. I need to drive down to you and have you help me align my Camaro!
Old 11-13-2023, 09:57 AM   #685
Infidel67
Life's just a Ride
Infidel67's Avatar
Drives: 2011 Synergy Camaro 2SS/RS LS3
Got my SS front Emblem Painted looks like crap I think but eh
2011 Synergy Camaro 2SS/RS Ls3, LTH, CAI
Custom Intake, TSP stage-3 111-LSA Cam, RWHP 503/508
Infidel67 is offline   Reply With Quote
Old 11-13-2023, 10:30 AM   #686
Danial
Danial's Avatar
Drives: 2013 SS/RS, 2015 Camaro SS/RS Vert
Damn, that's a great looking garage.
"Never cough into a full ashtray."
Danial is offline   Reply With Quote
