Vararam
Old 04-26-2023, 03:21 PM   #1
Thatred1le
Drives: 2014 Camaro SS/1LE
Dyno Numbers after TSP Stage 2 Cam
I recently modded my SS/1LE with texas speed 1 7/8 headers, high flow cats, and a TSP Stage 2 LS3 Cam (229/244 .629"/615” 112 LSA, 109 ICL). I am extremely happy with how it came out, the chop is amazing from the cam, driving on the street and at low speeds feels like stock and when you go above 3k rpm its like an entirely different motor, the sound is amazing with the stock NPP. Only question is my overall numbers are 485 whp and 410 torque. I notice some other people with the same set up as me make around mid 450s hp and mid 450s torque. My tuner also explained to me that he said I was spinning on the dyno a bit and as the torque curve starts to go up it drops back down and then stays flat.
If I had to take an educated guess my stock numbers were probably somewhere around 380 whp and 370 torque. The dyno was also done on a mustang dyno and I heard that they rate a bit lower than normal.
My question is is my torque a bit low for what I have done or are these completely normal numbers to have?
Thatred1le is offline   Reply With Quote
Old 04-26-2023, 03:53 PM   #2
Oxtar41
Oxtar41's Avatar
Drives: 700 rwhp 2010 SS
That dyno seems pretty generous for a mustang. Those are dyno jet numbers. Either way seems pretty healthy for just a cam and headers.
Oxtar41 is offline   Reply With Quote
Old 04-26-2023, 04:46 PM   #3
ss camaro-monte
Drives: 2015 camaro 2ss, 87 monte ss
Horsepower is a little high for mustang dyno but is in the realm of what it should be. It is low on torque some but either way I would think 470rwhp and 430tq would be an average for that cam imo with a stick car.
ss camaro-monte is offline   Reply With Quote
Old 04-26-2023, 08:06 PM   #4
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Also depends on the wheels you have and weather outside. Mine was done on a warm humid day and got 440hp and 405 torq with mods in sig. I’m also auto with factory 20” wheels
Bigdumogre is offline   Reply With Quote
Old 04-27-2023, 12:53 PM   #5
Bo White
Bo White's Avatar
Can't compare different dynos even same brand and model.
Totalled:
Old 04-28-2023, 01:26 PM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Agreed with above. I am running a TSP Stage 3 cam in mine, specs in sig, with the LOD manifold and got the same HP numbers as you, but a bit more TQ as my tuner ran the converter locked, and on a dynojet too. But you're in the ball park of what you should see. As we have always said here, dynos are for tuning, don't get hung up on any numbers, they're all different, how the car preform and runs is all that matters. Enjoy that Camaro!!
Old 04-29-2023, 01:25 AM   #7
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
torque is way low
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 05-02-2023, 08:52 AM   #8
eLeSthree
Drives: 2011 Camaro SS 6sp
https://www.camaro5.com/forums/showt...php?p=11200362
Read post #12.
Your dyno curve looks just like the first one I posted. I had too much timing in too early.
The more experienced tuner we took the car to, removed timing down low, then added a little up top. This made the car gain torque and feel more responsive overall, at the cost of a couple ponies up top. I would be curious to see your timing table.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 05-03-2023, 03:07 PM   #9
Thatred1le
Read post #12.
Im not sure how I would get my timing table would I call my tuner? I dont understand how I can gain that much horsepower but not gain that much torque. Is it worth trying to get another tune from a different shop? Or would it be worth trying it on another dyno to see what it makes. My tuner stated that it kept spinning on the dyno which is why it curves up and then drops and then curves back up again. He said that if I used another dyno the torque would go up. Im really not looking for anything crazy I was seriously expecting maybe 485hp which im at and around 430-440 torque to the wheels.
Old 05-03-2023, 03:09 PM   #10
Thatred1le
Those are some great numbers especially out of a L99, did you get dynoed on a mustang or dynojet? My tuner said that the mustang dyno usually is called a "heartbreaker dyno" because the numbers would be lower than I expected. Im not that upset about the horsepower numbers mainly just the torque numbers. Is it worth trying another dyno at another shop or just bring it to a 1/4 mile track and see how it does
Old 05-04-2023, 01:14 AM   #11
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Originally Posted by Thatred1le View Post
Those are some great numbers especially out of a L99, did you get dynoed on a mustang or dynojet? My tuner said that the dynojet usually is called a "heartbreaker dyno" because the numbers would be lower than I expected. Im not that upset about the horsepower numbers mainly just the torque numbers. Is it worth trying another dyno at another shop or just bring it to a 1/4 mile track and see how it does
I would try a different dyno at a different shop but just a dyno run not a dyno tune.
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 05-04-2023, 10:14 AM   #12
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
The mustang dyno is dubbed the “heartbreak dyno” not the dyno jet , from what I’ve read dyno jets gives higher ratings than the rest
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.7 @133.9
Risingson05 is offline   Reply With Quote
Old 05-04-2023, 05:00 PM   #13
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yes, as Risingson05 states, the mustang dyno are the "heartbreaker" dynos. Mine was done on a dynojet. My previous dyno tune was done on a Mustang dyno and the numbers were about 10hp and tq less than what I have in my sig. I would take it to another dyno shop and just do a couple pulls to see what you really have. Your tires should NOT be spinning on the dyno drum if they are in good shape and the car strapped down properly. Just doesn't happen with lower HP cars like ours.
Old 05-04-2023, 05:26 PM   #14
Thatred1le
yes you are correct i made a typo the dyno i used was a mustang dyno my mistake
