12-20-2019, 12:07 AM | #1 |
NOXQCES ZL1
Drives: 2017 Camaro ZL1 Join Date: Mar 2019
DIY DW400 Lowside Upgrade
My ZL1 ran out of lowside volume at around E40, so I decided to investigate retrofit of a DW400 into the stock fuel pump assembly. I purchased a new OEM fuel pump assembly, DW 9-403 pump and 9-1047 installation kit that worked out perfectly.
I went with the DW400 because it flows better than a Walbro 450 at 70 psi on E85, is a close physical fit, draws relatively low current for its flow, has an integrated check valve to retain fuel pressure, and includes a Venturi port for fuel transfer. The stock pump body is 43mm and the DW is 46, so mild dremel work is required to make the pump fit in the stock assembly. Additionally the stock check valve / filter input feature is removed, but creates a nice feature hold the pump in place. I modified the bottom filter assembly to turn it into a retainer with clearance for the DW filter. The only question at his point is if the FPCM will throw a code for the additional current draw. This pump will draw 17 - 20A at 13.5V |
12-20-2019, 06:07 AM | #2 |
Great idea, looking forward to seeing how it works out!
12-20-2019, 07:46 AM | #3 |
BAMF SS
Subbed
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
12-20-2019, 07:52 AM | #4 |
Drives: Turbo 6.2 Join Date: Feb 2019
This is great!
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
12-21-2019, 12:14 PM | #5 |
BAMF SS
Sooo I'm doing a little research and it looks like the ZL1 factory low side flows around 475 lph @ 0 psi. Do you think you will gain much fuel with thsy pump?
12-21-2019, 12:49 PM | #6 |
I think the more interesting question is: What does the ZL1 low side pump do at say 70 psi?
12-21-2019, 01:40 PM | #7 | |
NOXQCES ZL1
The stock pump is likely closer to the Walbro 255 in terms of the volume curve with pressure. |
12-21-2019, 01:46 PM | #8 |
NOXQCES ZL1
You can get a good sense for what the DW400 might flow at 0 psi if you extrapolate the this flow curve down to 0, but what’s really important is the flow characteristic over pressure.
12-21-2019, 11:34 PM | #9 | |
BAMF SS
12-22-2019, 12:21 AM | #10 |
BAMF SS
Actually nvm.... doing a little more research, I found a flow rating of 300 lph @ 30 psi for the lt4 pump
12-22-2019, 12:49 AM | #11 | |
NOXQCES ZL1
You found more data on the stock pump than I did and I appreciate that. Thank you. |
12-22-2019, 09:31 AM | #12 |
BAMF SS
Does the higher pressure ratings really matter though? I mean the low side is just supplying fuel to the high side, so as long as there is pressure behind it, it shouldnt change anything. It wont effect spray patterns or anything of that sort, like in a PI motor, if it starts running low at like 40 psi.
Post updates as it comes along.... I think you're onto something... a nice in tank pump would be a good fuel option for those who want to stay below 1000 rwhp or so
12-22-2019, 11:31 AM | #13 | |
NOXQCES ZL1
As a side note - the car is street tuned and this shows up in WOT 3rd gear (M6) but it didn’t show the same issue on the dyno. |
12-28-2019, 04:12 PM | #14 |
Drives: Camaro ZL1 Join Date: Jan 2018
Awesome work, you wonder why no one came up with this idea before and there is not a plug and play kit available. Please keep us posted if the pump helps the issue. cheers!
