02-19-2020, 11:26 AM | #1 |
Drives: 2011 SIM 2SS/RS 6M Join Date: Jul 2011
New build... won't start
Getting code P0016 changed both cam and crank sensors, new battery. Have spark, fuel, etc and found pic from build timing sockets are correctly lined up. Any thoughts?
Rebuilt engine, all new, C5R timing kit, TSP stage 2 blower cam, 2.9 whipple, 102TB, ported/ polished heads, Last edited by xqwzit; 02-19-2020 at 12:02 PM. |
02-19-2020, 11:36 AM | #2 |
What did you do too it?
02-19-2020, 11:44 AM | #3 |
check broken or worn out or broken timing chain tensioner. worn out sloppy chain.
02-19-2020, 11:52 AM | #4 | |
15 Year LS1Tech Member
Drives: 2010 ss 391ci LS3 Join Date: Apr 2017
Check for pinched/melted/damaged wires too
GJDM |
02-19-2020, 12:27 PM | #5 |
Ive added mods to OP and have checked wiring for loose connections and broken/ damaged wires.
02-19-2020, 12:48 PM | #6 |
Have you gone back over every single grounding point? One of the easiest things to forget is one of our many grounds.
Every point marked with a '2' is a ground location. Obviously a bit different since you have a blower on top, but close enough.
02-19-2020, 01:41 PM | #7 |
I have and did find one that wasn't connected. Which was reason it wouldn't crank. I will use this schematic when I get home to go over things again. Thx
02-19-2020, 01:54 PM | #8 |
Drives: Camaro SS Join Date: Jan 2013
I've been through a similar situation like this before with my trailblazer SS, and it was a ground.
Fully Built 416ci / Procharger F1X / Century Built 4L80 / ZL1 Differential / Alky Control Meth /Circle D Triple Disk / ID1300s / Fore Innovations Return / Kooks Full Exhaust / Holley HiRam / e85 / 15in Conversion on Forgestar Beadlocks / Tuner: Pat G
02-19-2020, 07:00 PM | #9 |
Checked all grounds again still won't go
02-19-2020, 07:58 PM | #10 |
Drives: cheby Camaro Join Date: Aug 2019
Are you using the cam phaser? If you are its not full of oil yet causing the cam timing to be all over the place. Crank it until you see oil pressure.
02-20-2020, 08:24 AM | #11 |
My car is a 6 speed manual
02-20-2020, 09:04 AM | #12 |
Pain in the ass, but if I were you I would get the technical manual and use the wiring schematics and diagrams. I've done this when moving my fuse box and did every single pin to every sensor in the entire car. I have the manual if you need it in pdf form.
02-20-2020, 12:02 PM | #13 | |
02-20-2020, 12:38 PM | #14 | |
