Old 07-23-2018, 02:38 PM   #1
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
New eLSD calibration for SS 1LE!
Coming Soon from Chevrolet Performance for your Camaro SS 1LE:
"Continuous on-track and street development combined with the pursuit of perfection have pushed our Camaro engineers to develop an eLSD calibration that will enable faster turn in and faster power application on turn exit.
This eLSD calibration will decouple the differential at a faster rate based on accelerator pedal position and steering wheel angle to enable faster yaw rotation at corner entry, and upon corner exit the eLSD will couple faster than normal rates to enable power to be delivered sooner to both rear wheels."
Stay tuned for pricing and availability!
Old 07-23-2018, 02:39 PM   #2
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 07-23-2018, 02:47 PM   #3
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
Awesome stuff!!!
I just got my 1LE last weekend, and I am already looking into the GMPP solid rear cradle hardware from the ZL1 1LE.
Nice to see there will be a e-diff. upgrade as well.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers)
Previous:
18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust)
16' F80 M3 (Ohlin R/T Coilovers)
13' Audi TTRS (APR Stage 1, MSS Springs)
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
TRZ06 is offline   Reply With Quote
Old 07-23-2018, 03:44 PM   #4
TrackClub
TrackClub's Avatar
Drives: 2020 SS 1LE (previous: 2017 SS 1LE)
Am i correct to presume this is for MRC suspension?
If so very sweet indeed!
TrackClub is offline   Reply With Quote
Old 07-23-2018, 03:50 PM   #5
JRL1LE
JRL1LE's Avatar
Drives: 2017 SS 1LE
https://www.camaro6.com/forums/showthread.php?t=532096
This is for primarily for autox and all nannies have to be off, it will not change anything with nannies on or in PTM.
JRL1LE is offline   Reply With Quote
Old 07-23-2018, 04:34 PM   #6
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Originally Posted by TRZ06 View Post
Awesome stuff!!!
No diff upgrade, just modified programming for the eLSD ECU.
No. This is for the eLSD lock-unlock programming.
'18 1SS 1LE Black, PDR
Old 07-23-2018, 04:53 PM   #7
TRZ06
TRZ06's Avatar
Yeah, that is what I meant. Common sense says it would not be the diff. itself.
Current:
Previous:
09' C6 Z06
08' E90 M3
03' C5 Z06
Old 07-23-2018, 05:00 PM   #8
TrackClub
TrackClub's Avatar
I guess i should have worded my question better:
Will this elsd tune apply to stock cars with mrc and tpm?
Or modded suspensions and no ptm collaboration as in the previous thread?
Old 07-23-2018, 06:19 PM   #9
S2K+1LE
Drives: 17 SS 1LE | 07 S2K
It applies to the vehicle as shipped, no way for GM to know and account for all parameters of the aftermarket.
S2K+1LE is offline   Reply With Quote
Old 07-23-2018, 07:15 PM   #10
TrackClub
TrackClub's Avatar
Just wondering due to post #5...
Old 07-23-2018, 07:19 PM   #11
JRL1LE
JRL1LE's Avatar
Drives: 2017 SS 1LE
It applies to stock cars and cars with modified suspension, It was programmed for modified suspension cars, but can help stock cars too.
Old 07-23-2018, 08:55 PM   #12
dontlifttoshift
Drives: 71 Camaro '18 1LE
Didn't we cover this already?
Donny
dontlifttoshift is offline   Reply With Quote
Old 07-23-2018, 09:37 PM   #13
Chris V
Chris V's Avatar
Drives: 2017 1SS 1LE
It’s for SS 1LE - 2017+
Does not change anything under PTM programming. Only enables the faster coupling and decoupling with all nannies off.
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq
Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers
Chris V is offline   Reply With Quote
Old 07-23-2018, 09:39 PM   #14
TrackClub
TrackClub's Avatar
Originally Posted by dontlifttoshift View Post
Maybe. As post #5 has already indicated with the same thread. BUT: this is how elsd works on a stock car with its 4 distinct modes:
eLSD modes change automatically when the traction control button is pressed as follows:
– Mode 1: The standard mode when the vehicle is started. Emphasis is on vehicle stability. Also used in PTM wet mode.
– Mode 2: Engaged when both TCS and StabiliTrak® are turned OFF. Provides more nimble corner turn-in, and is biased for better traction out of corners.
– Mode 3: Engaged when PTM is engaged in Dry, Sport 1 & 2 and Race Modes. Nimble calibration with similar functionality as eLSD Mode 2, however it is integrated to work with PTM.
– Mode 4: Engaged when TCS is selected OFF, but StabiliTrak® remains ON. Vehicle stability is still the priority, while allowing for optimized traction out of corners. Note: this is Competitive Mode.
So my question is this: does anyone know (vs quess) whether the new GMPP elsd tune will replace all 4 modes, or only some of the existing modes, or only mode 2?
