Vararam
Old 03-27-2024, 10:37 AM   #1
skippy01
Drives: 2011 Camaro SS
Oil message on dash
So started my 2011 SS and the message can up low oil need to fill I checked and the oil level was good on the oil stick any help would be greatly appreciated.
skippy01 is offline   Reply With Quote
Old 03-27-2024, 01:05 PM   #2
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
maybe you need a new one of these. check the wiring too.
12603781
https://www.rockauto.com/en/moreinfo...t=5700&jsn=644
FasNuf is offline   Reply With Quote
Old 03-27-2024, 01:27 PM   #3
skippy01
Ok thank you i was thinking life a oil pressure sending switch but i will try this and see if it fixes it. Thanks for your help.
Old 03-27-2024, 02:30 PM   #4
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
I had no idea these cars even had a Low Oil notification/light
InFiD3ViL is offline   Reply With Quote
Old 03-27-2024, 02:36 PM   #5
FasNuf
FasNuf's Avatar
Me either until I found this level/temp sensor in my pan. I've never seen a light , but I think it shows up on the DIC.
Old 03-27-2024, 02:38 PM   #6
FasNuf
FasNuf's Avatar
You said the display said "Low oil need to fill" , that doesnt sound like a pressure warning to me. They would tell you to shut the car off immediately if I remember right.
Old 03-27-2024, 07:09 PM   #7
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Even my 02 Silverado has an oil level sensor on the side of the pan. Pretty common on LS.
Old 03-27-2024, 09:51 PM   #8
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Good to know I guess but the dipstick is still my friend!
Moto-Mojo is offline   Reply With Quote
Old 03-28-2024, 03:07 AM   #9
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
A while back I had only put in like 4 quarts of oil in my car to start it and flush it, on the display it said low oil but didn't say shut the engine off.
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 03-28-2024, 06:30 AM   #10
FasNuf
FasNuf's Avatar
It doesn't say it when oil level is low, only when there's no oil pressure. Different sensor.
