Old 01-23-2024, 06:49 AM   #1
Seebueb
Drives: Chevrolet Camaro SS
Rohana RFC10 20''
Hello everyoneMy name is Ricco, I come from Switzerland. I would like to mount the following rims on my Camaro: (Gen 5, 2012, SS / Brembo Brakes)
Rohana RFC10
Front: 10 x 20
Rear 11 x 20
I'm not entirely sure about the ET. Front: ET 25. (no other option at Rohana)
I think that fits with the Brembos (with Tire 265/40/20 / the wheels sit nicely in the wheel arch)) Rear: There are ET 35 and 40 at Rohana
I tend to ET 40 so that the tires don't too far out. (With tires 305/35/20.)
Now my question: Do the ET40 fit or do I have to switch to ET35 because of the Brembos?
Do any of you have experiences with this?
best regards
Ricco
Seebueb is offline   Reply With Quote
Old 01-28-2024, 08:24 AM   #2
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
Welcome to the forum! Try this site out for the wheel and tire offset calculator.
https://tiresize.com/wheel-offset-calculator/
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 01-28-2024, 12:40 PM   #3
bsn
Drives: 2013 ZL1
ZL1 offsets will work with an SS
https://www.camaro5.com/forums/showp...27&postcount=3
P,S, Welcome to the forum!!!
bsn is offline   Reply With Quote
Old 01-28-2024, 12:52 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Rohana RFC10
Front: 10 x 20
Rear 11 x 20
best regards
Ricco
You should be good on which ever offset you go with on the rears. My old 20x10 Z28 replicas I had on the front were a +23, so the 25 you are looking at will work. On the rear my old 20x11 Z28 replicas were +43, the wheels I have now are 20x11.5 with a +30 and they poke outside the fender a bit. So on what you are looking at, the +35 will be farther out, and the +40 will be about 1/4 inch, or 5mm inside more. Hope this helps you.Good luck.
