02-04-2021, 10:13 PM | #1 |
Drives: 2010 Camaro V6 LT Join Date: Jan 2021
Flower seeds under manifold????
What the f***** is this???
02-05-2021, 05:57 AM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
Either debris collected while driving, or do you park in a garage? Being from Toronto your garage will probably be much warmer than it is outside right now, giving the local mice a nice warm home for the night - same thing happened to me; went to clean the engine bay after a winter and found not just leaves (which I occasionally do, collected while driving around) but chewed-up paper towels and whatnot; turned out (or figured) it was a mice home. I promptly set up mouse traps around the garage and caught several over the next few days.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
02-05-2021, 06:04 AM | #3 |
Squirrels or mice do that. They like the warm engine bay and store food in it and be aware they also like chewing on wires to take a look around for damaged wires.
02-05-2021, 09:16 AM | #4 | |
02-05-2021, 02:21 PM | #5 |
Drives: 2011 RS 2LT Join Date: Dec 2020
Rats nest. Sometimes there called tree rats.
Been there done that. Looks Ok. |
