Old 12-28-2010, 11:01 AM   #1
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Arrow Different Wheel Construction Types Explained
I get a lot of emails from new wheel shoppers, asking what the differences are between cast aluminum wheels, flow-formed wheels, 1-piece forged wheels, 2-piece forged wheels, and 3-piece forged wheels. I always take my time to explain the differences in construction methods, as I prefer to educate my customers in order to allow them to select the wheels that best fit their needs.
There are predominantly 6 different methods for construction of wheels. Each one varies in quality, weight, strength, and price. There are pros and cons for each type. Hopefully after reading this thread, you gain a better understanding of each.
1. Cast aluminum wheels
2. Flow-Formed / Rotary Forged wheels
3. 1-piece "Monoblock" forged wheels
4. 2-piece welded construction forged wheels
5. 2-piece bolted construction forged wheels
6. 3-piece bolted construction forged wheels
Cast Aluminum Wheels
These are the lowest priced wheels, and are typically what are found on production vehicles. Cast aluminum wheels are created by pouring molten aluminum into a mold that is shaped like a wheel. This produces a wheel casting. Some final machining work is then done to clean up the rough surface, and paint/finishing is applied.
Pros: Lowest price, easiest to mass-produce.
Cons: More brittle than forged wheels. Spoke details and edges aren't as sharp as a machined forged wheel. Heaviest weight of all wheel construction types. Lowest quality. Limited offsets, width increments, diameter selection available. Nearly impossible to repair when cracked or severely bent - safely, that is. A damaged cast wheel usually needs to be replaced.
Flow-Formed / Rotary Forged Wheels
Flow-Formed wheels start out identical to cast poured wheels, but with different hoop thickness. The casting process above is used to create the spoke pattern only. Then the wheel castings are put into a flow-forming machine to form the outer hoops. This is done using high heat and high pressure rollers, which "flow-form" the outer hoop. This results in a stronger outer hoop, with aligned aluminum grain structure. The resulting wheel is a cast faced wheel with a hoop that has properties similar to a forged wheel. They are stronger and lighter than cast wheels.
Pros: Low Price, Lightweight, Higher strength than cast wheels.
Cons: Cast face still lacks the sharp edges and details of a machined forged wheel. Limited width increments and diameters available. Hard to repair when severely bent or cracked.
Video on Flow-Forming process:
1-Piece Monoblock Forged Wheels
The term "Monoblock" is used throughout the industry to describe the 1-piece forged wheels. "Mono" meaning one, and "Block" meaning it was created from one block of aluminum. The block in this case is actually a round bar stock of high quality, aerospace-quality 6061-T6 Aluminum Alloy. The round bar is pressed in a huge forging machine, to stamp out a wheel shaped blank. Forging is a hot working process, and helps to align the grain structure of the alloy. This results in a very strong, very lightweight wheel construction material. The wheel blank is then flow-formed to create the outer barrel shape. Following that process, the wheel blank is loaded into a CNC milling machine and there the spoke pattern is milled out.
Pros: Lightest of the forged wheel construction methods.
Cons: Priced about the same as expensive 3-piece construction. Difficult to repair when bent or severely damaged.
2-Piece Welded Construction Forged Wheels
These are considered the entry level forged wheels, as they are priced slightly lower than 3-piece forged wheels. The centers start out as a blank of forged 6061-T6 Aluminum alloy, and the spoke patterns are CNC machined with a milling machine. The wheel hoop is also a forged aluminum material. On a 2-piece wheel, the center is simply welded to the hoop on the backside of the wheel. Some manufacturers also offer cast aluminum centers, to reduce cost. Quality and weight of the cast centers is not as good as forged/machined, however.
Pros: Lowest Price of the Forged wheels. Same weight, appearance, quality as 3-piece wheels.
Cons: Limited widths increments available. Cannot easily chrome plate or paint the lip, since it has to be welded on. More difficult to repair a bent lip compared to a 3-piece wheel, as the center has to be cut out and a new hoop welded on.
2-Piece Bolted Construction Forged Wheels
These are built very similar to the 2-piece welded construction wheels above, but use a hoop that has a bolting ring already in place. Instead of welding the center to the hoop, it is simply bolted on. This is the least common method of forged wheel construction, as the hoops tend to cost more than simple welded hoops. Some manufacturers also offer cast aluminum centers, to reduce cost. Quality and weight of the cast centers is not as good as forged/machined, however.
Pros: Lips can be easily chrome plated or painted, since no welding required. Easier to replace a hoop when it gets bent.
Cons: Limited width increments available. Few brands offer this type.
3-Piece Forged Wheels
Three piece forged wheels are usually the most expensive wheel construction, mostly due to the assembly labor and components used. The wheels consist of three main pieces; the center, the outer hoop (lip), and the inner hoop. These three parts are held together with a series of perimeter bolts. Silicone RTV is used to seal between the two hoops. Some manufacturers also offer cast aluminum centers, to reduce cost. Quality and weight of the cast centers is not as good as forged/machined, however.
Pros: Most width increments available, truly perfect fitments available. Easiest of all wheels to repair if lip gets bent or damaged, as hoops are easy to replace. Easy to paint or chrome plate lip, since no welding is required. Can have different color rear hoop and outer hoop, since they are two different pieces. Highest resale value for used wheels.
Cons: Most expensive forged wheel construction. RTV silicone seal can be damaged by inexperience tire installers, resulting in leaks.
Thanks for reading! Feel free to ask any questions regarding wheel construction, I'll try my best to answer you.
Tony
Fquick.com/NineBall
Nine Ball is offline   Reply With Quote
Old 12-28-2010, 11:06 AM   #2
Indpowr
Drives: Corvette C6
Wow. Amazing post to help people know what to buy. Props on taking the time to do this!!
Old 12-28-2010, 11:41 AM   #3
MMXI SS
MMXI SS's Avatar
Drives: 2013 VR ZL1
Awesome information. I will be contacting Tony when it's time for new wheels!
Thanks Tony
MMXI SS is offline   Reply With Quote
Old 12-28-2010, 11:54 AM   #4
spyderbuddy
spyderbuddy's Avatar
Drives: 2010 RS Inferno Orange Metallic
The Camaro's Wheels (20") are cast correct?
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
spyderbuddy is offline   Reply With Quote
Old 12-28-2010, 11:56 AM   #5
JUISSD
JUISSD's Avatar
Drives: 2010 White/IOM 2SS/RS M6
Very informative, thanks for posting it up. I can't wait until I can afford a set of nice wheels. Nothing changes the appearance of a car or sets it off more than the perfect wheel choice.
2010 White/IOM Camaro 2SS/RS M6
JUISSD is offline   Reply With Quote
Old 12-28-2010, 11:56 AM   #6
Nine Ball
Nine Ball's Avatar
Yes, factory Camaro wheels are cast aluminum...and heavy.
Fquick.com/NineBall
Old 12-28-2010, 12:44 PM   #7
alssiri
alssiri's Avatar
Drives: 2017 ZL1 A10
Thanks for the great info Tony
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir
Glassskinz rear window valance .
2012 ZL1 A6 (SOLD)
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
alssiri is offline   Reply With Quote
Old 12-28-2010, 12:48 PM   #8
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
Thanks for this post Tony.
Old 12-28-2010, 01:28 PM   #9
JUISSD
JUISSD's Avatar
Info like this should probably be a sticky.
Old 12-28-2010, 01:39 PM   #10
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Very good info about stuff I've never understood... Thanks
Black 2SS ordered 1/4/2010, received 2/19/2010
clg_98ta is offline   Reply With Quote
Old 12-28-2010, 01:56 PM   #11
tlc9193
The Original
tlc9193's Avatar
Send a message via Skype™ to tlc9193
Do any of these different methods play a role in picking wheels with a cetain HP? Are there limits to each method based on HP of the car?
LETHAL RACING Phase V, "ECS Supercharger, Nightfury cam, Methanol Injected, Dual Fuelpumps, Kooks Headers with Hi Flow Cats, 3'' Catback Magnaflow Exhaust, Custom Tune, H & R Drop Springs,Barton Ind. STS 773 RWHP.
tlc9193 is offline   Reply With Quote
Old 12-28-2010, 02:04 PM   #12
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Thanks for the GREAT info Tony.
I vote for STICKY too.
rtcat600man is offline   Reply With Quote
Old 12-28-2010, 04:03 PM   #13
Nine Ball
Nine Ball's Avatar
Wheels are rated for dynamic loads, not HP. The lug nuts on your car will be the weak link, not any wheels themselves. If you are searching for performance primarily, simply pick the lightest wheels that you can afford. Weight saved on rotating items is far more important than static non-moving mass.
Fquick.com/NineBall
Old 01-02-2011, 08:05 AM   #14
Nine Ball
Nine Ball's Avatar
Bump for the new year. Educate yourselves on quality before making that expensive purchase
Tony
Fquick.com/NineBall
Tires loosing pressure joepitt Wheels and Tires Talk Sponsored by The Tire Rack 22 12-11-2010 05:00 PM
NEW MODEL: 22X9,22X10.5 WL26 WHEEL TIRE PACKAGES! GREAT PRICES!! BestWheelDeals Wheels / Tires 27 09-14-2010 07:05 AM
2010 Camaro Wheel Locks Caution... willie2323 Wheels and Tires Talk Sponsored by The Tire Rack 3 06-20-2010 09:41 AM
So what is the difference between wheel construction types?? Mindz Wheels and Tires Talk Sponsored by The Tire Rack 3 12-21-2009 06:42 PM
