03-27-2024, 10:37 AM | #1 |
Drives: 2011 Camaro SS Join Date: Feb 2024
Oil message on dash
So started my 2011 SS and the message can up low oil need to fill I checked and the oil level was good on the oil stick any help would be greatly appreciated.
03-27-2024, 01:05 PM | #2 |
maybe you need a new one of these. check the wiring too.
12603781 https://www.rockauto.com/en/moreinfo...t=5700&jsn=644
03-27-2024, 01:27 PM | #3 |
Ok thank you i was thinking life a oil pressure sending switch but i will try this and see if it fixes it. Thanks for your help.
03-27-2024, 02:30 PM | #4 |
I had no idea these cars even had a Low Oil notification/light
03-27-2024, 02:36 PM | #5 |
Me either until I found this level/temp sensor in my pan. I've never seen a light , but I think it shows up on the DIC.
03-27-2024, 02:38 PM | #6 |
You said the display said "Low oil need to fill" , that doesnt sound like a pressure warning to me. They would tell you to shut the car off immediately if I remember right.
03-27-2024, 07:09 PM | #7 |
Even my 02 Silverado has an oil level sensor on the side of the pan. Pretty common on LS.
03-27-2024, 09:51 PM | #8 |
Fast Cars and Old Guitars
Good to know I guess but the dipstick is still my friend!
03-28-2024, 03:07 AM | #9 |
A while back I had only put in like 4 quarts of oil in my car to start it and flush it, on the display it said low oil but didn't say shut the engine off.
03-28-2024, 06:30 AM | #10 |
It doesn't say it when oil level is low, only when there's no oil pressure. Different sensor.
