Old 06-28-2022, 07:17 PM   #1
jesse121pm
jesse121pm's Avatar
Drives: 2012 Camaro 2ss 45th anniversary
Transmission Fluid Flush
I am trying to switch my transmission fluid to redline d4 atf because I heard it would help with my 2nd gear grinding sometimes. I was wondering if there is a filter and how much do I put into the car when doing a complete flush. Its a tr6060.
jesse121pm is offline   Reply With Quote
Old 06-29-2022, 06:07 AM   #2
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
Jesse, it depends on if you have a trans cooler or not. 3.65 quarts without and 4.22 quarts with a cooler. There is no filter.
NOT A 45 is offline   Reply With Quote
Old 06-29-2022, 12:42 PM   #3
jesse121pm
jesse121pm's Avatar
Do i have to get it on point of 4.22 quarts or do i just fill it up till it starts dripping out?
Old 06-29-2022, 12:49 PM   #4
NOT A 45
NOT A 45's Avatar
You got it.....that's just the approximate capacity. Buy yourself 5 quarts and your good.
Old 06-29-2022, 01:31 PM   #5
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Good call on the RedLine D4 ATF, that's the good stuff for the TR6060. In my experience (and I've been through it a few times now) you can drain it as long as you want, but you'll never get a full 4qts out of it, and so having 4qts on hand is plenty to get you topped back off. Like you said, fill till it runs out the fill plug, and you're good.
Old 06-29-2022, 01:57 PM   #6
NOT A 45
NOT A 45's Avatar
I imagine the remainder stays in the cooler unless you pull the line off.
Old 06-29-2022, 02:09 PM   #7
acammer
acammer's Avatar
Yea, seems right. I freshen it up every 10k miles or so, and therefore I'm not super concerned about getting every last drop.
Old 06-29-2022, 02:48 PM   #8
ADVMax
Sporting Foole
ADVMax's Avatar
Drives: 2010 Camaro SS
Another vote for the Redline D4. Mine shifts like buttah.
ADVMax is offline   Reply With Quote
Old 06-29-2022, 11:12 PM   #9
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Drain and fill will almost take 4 quarts. Had a little extra left in my gallon of Amsoil.
Badbubba is offline   Reply With Quote
transmission, transmission fluid
