02-08-2017, 04:29 PM | #1 |
Drives: 2016 2SS Join Date: Oct 2016
2017 ZL1 axles on 2016/17 SS
I am installing my procharger system on my car in coming weeks and keep thinking of which mods I would like to add to support the additional power. I know that I will need to upgrade my drivetrain soon if I want to do any kind of launches. The aftermarket options are very expensive as we all know and are overspec for the kinds of power that I aim for in my build(not going much over 600whp for now); I have no problem dishing out the extra cash for the axles available from DSS or gforce if there are no other options. Has anyone looked into ordering the axles from the ZL1 or know anything regarding the quality of the stock ZL1 drivetrain parts? I hope they become available as a cheap yet reliable alternative to some of the more expensive offerings out there.
02-08-2017, 05:04 PM | #2 |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
I thought they wouldn't work because the E-Diff housing is wider and the axles are thus shorter?
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
02-08-2017, 05:08 PM | #3 |
Thanks for the input, this is why I asked! I wasn't sure if anyone had really looked into it yet. As far as I can see they aren't for sale from any GM parts site yet.
03-22-2017, 01:42 PM | #4 |
FMPG
Drives: 2016 2SS Join Date: Dec 2015
I think you're going to need the entire assembly and not just half shafts. I looked into this a while back and was told that the spline is different between the two cars. So if you go with the ZL1 parts, it's going to cost twice as much as just ordering the aftermarket stuff. The stock SS axles are a lot stronger than you think. I've read that they've been able to handle over 700rwhp but I'm not sure if that's with drag radials or what kind of tires.
Ordered 3/8/16- NFG/Ceramic White, M6, MRC, NPP, 6 pots, blk blade, no sunroof, blk splitter, blk bow ties, dark tails, nav.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge 93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno) |
03-22-2017, 07:00 PM | #5 | |
03-22-2017, 10:01 PM | #6 |
I'm putting down almost 544/559, I launched my car a bunch of times at the track and the axles are holding up just fine so far. I'm running slicks instead of drag radials and there is a reason for that. They don't hit the drive train as hard as a drag radial since they side wall wrinkles as the car launches. I will have about 600 rwhp once I retune and start running VP109 so the slicks will be more important then ever.
03-23-2017, 03:59 AM | #7 |
Drives: 2017 Camaro 1SS Join Date: Aug 2016
Is your car M6 or A8? Going to use sticky tires, not the stock ones?
03-23-2017, 07:03 AM | #8 | |
FMPG
So far no car meets or anything but there's a thread for CT Camaro guys on the 5th gen board: http://www.camaro5.com/forums/showth...3&goto=newpost I used to live in Stamford for a while and am still close by if you ever want to get together...and it's the Governor's Republic. The people don't get any real say unless they agree with him LOL!
03-23-2017, 10:13 AM | #9 |
Drives: 2017 Nightfall Grey Auto 2SS Join Date: Mar 2012
Gforce 9 inch and Level 5 HalfShafts should hold up fine for you
You should you fine on your stockers unless you get a bunch of wheel hop. |
03-23-2017, 11:15 AM | #10 | |
I'll check out the CT thread, I haven't really explored Camaro5 much yet hence not finding it. The only "local" car meet I go to every once in a while is the one at Bear Mountain in the summer, there are always some nice rides there; it would be nice to have something a little more local as I know there are a ton of car guys in our area. Which track do you go to around here? |
03-23-2017, 01:33 PM | #11 | |
FMPG
Gforce also told me it should be ready for production in about a month. You won't be able to use the same driveshaft and axles though that fit the stock rear, so I'm going to wait for the 9" kit to come out. Gforce will be also be releasing their carbon fiber drive shaft for the 9" kit around the same time and I was told it will be around 7lbs. lighter than their competition's. Keep us posted on your testing if you don't mind. I'll try to take it easy until I know they're almost ready I haven't been able to find out too many details on the GM solution for using a 5th gen ZL1 rear diff on the 6th gen SS other than the GM video on Youtube from Sema. What I was told though is that it's close but not a direct fit. The front bracket is about 1/2" off and needs to be moved. There are few shops that fabricated some one-off solutions for customers, but I think we're much better off waiting for a true 9" kit to become commercially available rather trying this on our own. Gforce seems like they're very focused on getting this done and done right for the gen6 SS. The DSS 9" kit still seems like it's in testing as well. They were the first to try this on the gen6 but I got the impression that they're not as close to a finished product and priorities have shifted to other cars since the initial prototype install we saw in Hot Rod Magazine. I want to be clear though that those exact words were not spoken to me, but it's easy to read between the lines. They didn't have an ETA on commercial availability either, but they could do something custom if you purchase the gen5 9" kit from their website.
03-23-2017, 02:39 PM | #12 | |
haha yes Chris is coming up to drink a few cold ones and just kick back. The car is at ProCharger getting a F1A set up put on so testing will be a little while longer. Gforce 9" package will be the center section/ halfshafts and a DS. Once we get mine in they will measure for the drive shaft and it will be a plug and play kit. As for the other brand I don't know anything about it. I'm a Gforce guy only.. I've know Chris since the beginning back when I was playing with GTO's and he was just getting started in his home garage. |
03-23-2017, 02:56 PM | #13 | |
FMPG
03-23-2017, 03:01 PM | #14 |
The SEMA "Drag Pack" cars had a hybrid 6th/5th Gen ZL1 setup that Chevy claimed they had not broken at the 600hp level. Looking at the parts list, appears they used ZL1 driveshaft & half-shafts.
https://theblock.com/news/sema-2016-...opment-concept http://media.chevrolet.com/media/us/...1031-copo.html |
axles, boost, supercharger, zl1 |
