05-05-2019, 10:49 PM | #29 | |
Tactical Garage
Drives: 2016 Camaro 2SS Join Date: Nov 2016
05-08-2019, 10:08 PM | #30 |
Tactical Garage
In logging the control module voltage at the stock 14.7 fuel minimum voltage setting I am seeing 13.4 for control module voltage. When I increased the fuel min voltage to 15.5 the control module voltage increased to 14.3. I will bump the fuel min volt to 16.5 and log the control module voltage to see where it goes to.
For the guys that have installed the BAP, what are you seeing for control module voltage? 17.5 volts? |
05-09-2019, 07:02 AM | #31 |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
Odd. I'm only seeing 13.70 on my Control Module with the BAP in my HPTuners log. Should that be over 17 volts or is that something that Data logging is not going to pick up?
Former Ride: 17 Camaro 2SS, M6 - Fifty | Procharger P1SC | 3.7 Pulley | Stage 2 IC | Race Bypass | DSX FF Kit | JRE Custom E85 Flex Fuel Tune | LT4 Fuel System | JMS Voltage Booster | MSD Plug Wires | American Racing 1-7/8's LT Headers Full System Catback | Baro Breakout Harness | LT4 Map Sensor | Katech Ported TB | MMS Oil Catch Can | 160 Thermo | Solo Performance J-Pipes
05-09-2019, 07:43 AM | #32 | |
2016 NFG 1SS A8
05-09-2019, 01:34 PM | #33 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Has anyone had any luck being able to license the FPCM in a 1LE car? All I see is the CCM module, there is no FPCM when I try to read anything. I am on a Jannetty tune as well using a JMS BAP in the mean time but am limited to E40. I am tackling the HPFP fuel line next as I have read that line has an orifice in it that was cause all sorts of issues with the HPFP fuel pressure dropping.
Also has anyone replaced the HPFP fuel line under the intake with the one that doesnt have an orifice in the line?
2019 Corvette Z06 2LZ A8 - Halltech CAI, AWE non-catted X-pipe, Mamo V2 ported TB 592rwhp, bone stock 566rwhp
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
05-11-2019, 09:06 PM | #34 | |
05-13-2019, 09:31 AM | #35 | |
05-13-2019, 10:00 AM | #36 | |
Ted.
www.jannettyracing.com
07-01-2019, 01:27 AM | #37 |
Drives: Chevy corvette Join Date: Jun 2019
Anyone tried upping the voltage through the tune with good results?
07-01-2019, 07:27 AM | #38 |
We do that in conjunction with the JMS but it will never provide the additional fuel a JMS does.
07-03-2019, 02:26 PM | #39 |
07-03-2019, 03:39 PM | #40 | |
That depends on what pump and injectors we are talking about,
07-06-2019, 05:46 AM | #41 |
07-08-2019, 08:22 AM | #42 | |
Ted.
