Old 04-19-2022, 01:47 PM   #1
nicserrentino
Drives: 18 camaro zl1
Flex fuel issue
So my car is in the shop and the tuner/owner just told me they’re dealing with fuel pressure issues on e85. They said it’s apparently common and they’ve shimmed the high pressure pump in hopes to fix it. I have the dsx kit. Just want to get Inputs from you guys that have used this kit and if y’all ever dealt with this
nicserrentino is offline   Reply With Quote
Old 04-19-2022, 02:06 PM   #2
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Well you need to feed the engine ABOUT 30% more fuel when using E85 vs. 93. Normally that is taken care of my modifying the fuel delivery tables so that it delivers more fuel to the engine if E85 is present vs. just gasoline. This assumes that you have enough fuel pressure and fuel volume to support whatever power level you have. For example your fuel pump might be able to support 550HP on GAS but MIGHT NOT be able to support that same power level on E85.
I run E85 on my daily driver 2019 SS 1LE and I get about 12MPG on E85 and around 15MPG on 93.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 04-19-2022, 05:53 PM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
most cars can go to about e45-50 without any fuel pump changes...most choose to go with a voltage booster for the in tank low side pump instead of mods with the high pressure pump
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 04-23-2022, 07:41 AM   #4
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Drives: 16 SS & 17 ZL1 Both Yellow
Send a message via Skype™ to EDFHOBBIES
low side pump or booster, Headers, intake, and TB would be the limit of running pump e85 assuming pump e85 is around e50 to 60% Adding a pulley or porting and you will be in that 30 to 50% range.
id like to buy the 4 to 6 good piston and rods after the failure please.
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber
EDFHOBBIES is offline   Reply With Quote
Old 04-23-2022, 10:01 AM   #5
airtroop01
Drives: 2018 Cadillac CTS-V
Not sure what shop is doing the work, but assuming they know what they’re doing, I had a similar issue and tons of fuel pressure issues. I ended up replacing the HPFP and still had the problem. Double checking every connection and everything altered underhood. Problem ended up being the feed line to the HPFP has an internal check valve which failed. You couldn’t tell from the outside of the line obviously since it looked new. Replaced the line and everything fired up and ran perfectly on the dyno afterwards.
airtroop01 is offline   Reply With Quote
Old 04-23-2022, 11:50 AM   #6
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Good point! LPE makes hiflow and I picked up 8 psi on lowside
Old 04-23-2022, 02:17 PM   #7
BlaqWhole
Drives: 2017 Camaro ZL1 A10
This is why I don't mess with that crap. "Oh it's soo simple", "E85 is soo easy to deal with"...yea, and then you find out you can't run this you can't do that your max is 40 if you have this but 27 if you have that you need a low side you need a hp dfi tb3 4x 50hdmi with a pip29 controller on the high side if your pulley is blue...it's not worth the aggravation.
BlaqWhole is offline   Reply With Quote
Old 04-23-2022, 03:13 PM   #8
Z OH 6
Drives: 2021 Red Hot ZL1
E85 is certainly more challenging and expensive on the LT4 platform. It's cheap and easy on the Hellcat platform. That being said, it's hard to beat $2.50 race gas
Z OH 6 is offline   Reply With Quote
Old 04-23-2022, 04:57 PM   #9
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I have 90 more WHP on E50 (vs 93 octane) that would say otherwise…
Old 04-23-2022, 05:29 PM   #10
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Same here. And I’ve never had a problem with it and never been confused by any aspect of it LOL.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
CW3SF is offline   Reply With Quote
Old 04-23-2022, 08:07 PM   #11
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
GM LT stuff is by far the easiest platform to run Ethanol on with the flex fuel sensor. The ECU adjusts the tune on the fly for whatever percent Ethanol is in the system. All you have to do is log your car or have a dyno shop log the car and find out how much Ethanol the setup can run. Then you simply mix the E with Pump gas at the pump to stay around that percentage.
Most other platforms require being hard tuned for E which means if the Ethanol percent in the system changes then you have to manually adjust the Tune.
Either way feel free to stay on 93 and get gapped by cars with less mods on E...
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 04-23-2022, 08:12 PM   #12
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
There is no aggravation, you are reaching with these made up problems. You upgrade your fuel system (once) and get a tune that supports x% ethanol, and then you blend 93 and E85 to have less than x% ethanol in the tank each time.
If even this is too much, you upgrade your fuel system (once) with a tune for 85%+ ethanol, and then you can put any mix of 93 and E85 into the tank anytime, basically "fire and forget".
I can understand you personally don't want to mess with "that crap", but then just say that, no need to try and make it look worse than it is.
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 04-24-2022, 05:26 AM   #13
Z OH 6
They have flex tunes on the Hellcat platform. The tune will automatically adjust based on the ethanol content that the factory wideband 02s read from the exhaust stream. No need to adjust the tune based on ethanol content. They also have flex fuel sensors too which works just like the LT platform, this is a newer method to adjust the tune, only a few tuners started going this route in the last 2 years. What makes it so much cheaper and easier on the Hellcat platform is that all you need is dual in tank fuel pumps, FIC 1200cc or ID1300x2 injectors and a flex tune and you're good to go to run full E85 well over 1000whp before some people will switch to 1700cc injectors. LT platform require so much additional fueling that it becomes very expensive quickly if you want to go over 700whp
Old 04-24-2022, 08:49 AM   #14
KingLT1
KingLT1's Avatar
This is true if all you like to do is bench race dyno numbers. Fortunately there are other metrics that play a bigger roll in how a car performs. Power to weight ratio is one example.
Either way It's not like any of these cars are cheap to buy and most that can afford them can afford a few extra thousand on fueling if need be.
2016 NFG 1SS A8
dsx, e85, flex fuel, fuel pressure
