04-24-2022, 11:23 AM | #15 | |
You lost me there, there's a ton of Hellcats in the 8's, and a few in the 7s, and two in the 6's but those two are pretty much full blown race cars. They aren't bench racing, it's a cheaper platform for drag racing without question. What a Hellcat will not do is corner with a Camaro. Regardless, I was just letting you know that the Hellcat platform is quite easy to setup on E85,and not just a blend, full E85 up to well over 1000whp without ever going into the engine. With the toohigh plates out now for the LT platform, that helps some for those that don't want to go internal but none of that is cheap either |
04-24-2022, 06:36 PM | #16 | |
Either way I don't really care if the Hell Cat fuel system is cheaper to mod. My point was it's worth the investment on the LT platform to run E. They simply run better on higher octane fuel due to the higher compression.
2016 NFG 1SS A8
04-24-2022, 07:05 PM | #17 | |
Drives: 19’ ZL1 A10 / 16’ C7Z M7 Join Date: Apr 2021
04-24-2022, 08:26 PM | #18 |
The only race cars I was referencing were the Hellcat's in the 6's. I agree E is worth the investment if you want to go over 700whp.
04-24-2022, 08:27 PM | #19 | |
They have flex fuel sensors for Hellcats too. Either way, Hellcats are cheaper for drag racing. Last edited by Z OH 6; 04-25-2022 at 09:03 AM. |
04-25-2022, 07:12 AM | #20 | |
Drives: 18 camaro zl1 Join Date: Dec 2020
whatcha mean by that last part about 4-6 pistons lol |
04-25-2022, 07:19 AM | #21 |
Heh, he wants to be at the head of the line for the pistons that'll be saved when your motor grenades, cunning move
04-25-2022, 07:42 AM | #22 |
04-25-2022, 08:18 AM | #23 | |
One way to avoid this is mixing E85 down to a safer percentage, I read that the gains beyond ~E60 were minimal anyway, so diminishing returns definitely seem to apply here.
04-25-2022, 08:29 AM | #24 | |
04-25-2022, 08:39 AM | #25 |
Drives: HBM ZLE Join Date: Aug 2017
Just for reference, from e20 to e60 with the cam was an increase of 50 whp.
04-25-2022, 05:02 PM | #26 | |
The 50/50 ratio, if you indeed put E85 (that is, 85% ethanol) in along with 93 (that has 10% ethanol) would result in ~E47-E48. You can install some smart gauge (Banks, for example) that will show you the current E percentage if you want to go fancy, or you can simply datalog the car and read out the current percentage. BTW this is my first flex fuel application, too, so hopefully those with more experience will chime in if I forgot something.
04-26-2022, 08:25 AM | #27 | ||
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
For the record guys, I have an E tune along with the DSX flex fuel sensor. I can go up to E44 with my tune and it made about 30 more RWHP over my 93 octane tune. But not for nothin, the same guys talking about how great E85 is because it'll "gap" this or that...well so will an EV, lol!! So by your same argument you all should be welcoming EVs with open arms since stock EVs are gonna gap E85 tuned modded ZL1s. Just sayin. Anyway, OP, any reputable shop should not be having an issue with this. First off they have to disable the code that pops up when you use E85 since it makes the ECU think you have less fuel pressure than you really do. Also there is fine tuning between mods and boost and how much ethanol you want to run. It's like a seesaw...a little more of this means less of that and a little more of that means less of this. As they are tuning it the will be able to see what their limits are and they can go from there. I'm sure they can figure it out if they're worth their salt. |
04-26-2022, 09:19 AM | #28 | |
dsx, e85, flex fuel, fuel pressure |
