Old 06-02-2020, 10:27 PM   #1
IowaLS31LE
IowaLS31LE's Avatar
Drives: Chevy Camaro SS 1LE
Whipple on E85 wanna go with smaller pulley
So I have a 2014 camaro ss 1le , currently have stock bottom end , stage 4 pds cam, headers , corsa exhaust, e85, 2.9 whipple on a 3.875 pulley. I made 700whp. Can I go with a 3.75 pulley and still be ok ? Worries about breaking. Also considering 3.65 pulley
IowaLS31LE is offline   Reply With Quote
Old 06-02-2020, 10:52 PM   #2
Rons1le
Rons1le's Avatar
Drives: 2015 Camaro 2SS RS 1LE AGM
How much boost are you at?
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
Rons1le is offline   Reply With Quote
Old 06-02-2020, 11:17 PM   #3
IowaLS31LE
IowaLS31LE's Avatar
9 pounds
Old 06-03-2020, 09:24 AM   #4
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
Originally Posted by IowaLS31LE View Post
9 pounds
you will be fine....the motor should take about 800rwhp.
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
gm2376 is offline   Reply With Quote
Old 06-03-2020, 11:28 AM   #5
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Anything over 650whp is considered risky. You could probably drop 2 sizes and be ok but it's a risk. Seems like a pretty conservative tune since i'm at the same power on 93
Greenhornet2 is offline   Reply With Quote
e85, pulley, supercharged, whipple
