Old 12-23-2019, 02:04 PM   #1
DBHWT
DBHWT's Avatar
Drives: 2013 SS 1LE
Ceramic coating
Beside price and durability, can anyone tell me any do's and don'ts on ceramic coatings once applied ? Thanks in advance Merry Christmas !!!
DBHWT is offline   Reply With Quote
Old 12-23-2019, 05:16 PM   #2
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Wash it properly, use an SI02 sealant on top of it.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 12-23-2019, 07:06 PM   #3
DBHWT
DBHWT's Avatar
Drives: 2013 SS 1LE
Thanks Joe for the input !!!
Old 12-23-2019, 09:10 PM   #4
Joe M 2012 2SS
Drives: 2012 2SS
Glad to help.
You will be surprised how easy your car will be to clean with the coating on the paint.
If you don't want to use a wipe on/wipe off SI02 product for your "sacrificial" layer on top of your coating, you can just use a soap infused with SI02 as well.
Adams Wash & Coat is very easy to use and leaves a layer of protection that lasted 9 weeks on my un-garaged daily driver.
https://www.camaro5.com/forums/showthread.php?t=553300
After you wash the car, before you dry it, do 1 last rinse, a pooling rinse, this will remove 90% or more of the water on your car, leaving you very little to dry. It only takes a couple minutes, and the key to it's effectiveness is using a slow stream of water that doesn't splash as you go across the car.
Old 12-25-2019, 12:45 PM   #5
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Originally Posted by Joe M 2012 2SS View Post
Glad to help.
Thanks Joe!
Adam's Polishes is offline   Reply With Quote
Old 01-16-2020, 12:10 AM   #6
rdanzel
Drives: 2010
Apply a booster product that is formulated to work with coatings.
rdanzel is offline   Reply With Quote
