09-20-2022, 01:12 AM | #1 |
Drives: 2011 Chevrolet Camaro SS L99 AT Join Date: Oct 2021
Noise, clicks, delays in DIfferential
Hello, could anybody advise me with my differential issue..
Unusual noise is coming from the diff, dips and delays are felt when releasing throttle and subsequent acceleration. This constant extraneous noise presents always, but it's best at speeds 40-65 mph, the higher the speed, the higher the pitch of the sound. Metallic clicks are also often heard when starting off. I checked the CV Axles but no backlash was found. The only play is inside the differential, if you check through the drive shaft.. The dips and delays are very similar to the late operation of the solenoids in the automatic transmission, however, my tranny and TQ are after disassembled full revision, with replaced TCM. I bought everything but in doubt, do I need something else for diff restoration ? I bought for GM 8.6" IRS and hope it's exactly my diff. Gear oil ACDELCO 104016 and additive for LSD ACDELCO 104003. |
09-20-2022, 07:03 AM | #2 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
The clicking could be lack of or worn axle washers. Go between the axles and hubs. Literally say anti click on the parts catalog. GM part number is 11611965.
As for the fluid. You can get ac delco fluid with the ls additive. GM part number 89021677
More to come. |
09-20-2022, 07:37 AM | #3 |
I don't know that a worn diff is causing "dips and delays". If I remember correctly you have a fairly low mile car?
09-20-2022, 08:32 AM | #4 |
Thank you very much ! I replaced left CV Axle 3 month ago with Trakmotive, but clicks returned (maybe diff sound?). By sound, I meant a drawn-out howl, like on old trucks. In my understanding, bearings are collapsed and pinion ring is worn out
09-20-2022, 08:35 AM | #5 |
09-20-2022, 10:52 AM | #6 |
So it appears you have a full rebuild kit coming for the rear along with new gears, Now I am not saying this is your issue or not but if I were you and doing all that you really should rebuild or replace your Differential, they are known to wear, I would install a True Trac ( Which I did in 2 of my vehicles ) or at least a stock type. and 8.6 IRS is correct.
09-20-2022, 11:43 AM | #7 |
SomeguyK
Howling is usually pinion bearing related. A full rebuild with a trutrac may be needed.
More to come. |
11-16-2022, 08:26 AM | #8 | |
Maybe you have any thoughts on this case...
2011 Chevy Camaro SS AT L99 / Stock / Daily Driver
1972 Plymouth Barracuda RB V8 3X2-barrel Holley R-4382A/R-4375A/R-4383A (Hamtramck) / Stock / Weekend Driver |
11-16-2022, 08:55 AM | #9 |
There are MEVOTECH H512399 rear wheel hubs in our local store , will try to replace them
01-14-2023, 08:53 AM | #10 | |
Drives: Chevy Camaro SS 2012 Auto/TR Join Date: Dec 2022
Now, after replacement, I have the same when throttle is applied only... Adjustment was done by diff repair station with a dial micrometer. Any suggestions ? |
