04-30-2022, 07:59 AM | #1 | |
Drives: 19 Z06 Join Date: Nov 2011
Did we just find the best catch can?
OK, so I got a bunch of mail asking about the E2-X, as the last video I did was the ultra and not a lot of people use the ultra. What I did was run the E2-X on the LT4 engine for about 300 miles, and then do the same with the MightyMouse. To save you the trouble if you don't want to watch the video the Elite did very well. I am not affiliated with any company
Gone but not forgotten:
1974 Corvette Stingray 454 1986 Z28 2009 Mustang GT convertible 2012 45th 2SS Vert 2013 ZL1 M6 2014 Zl1 M6 2014 GT500 2016 Challenger Hellcat M6 www.youtube.com/c/garageking |
04-30-2022, 08:56 AM | #2 |
And here we go...
04-30-2022, 09:24 AM | #3 |
I run a standard mishimoto catch can combined with a metco valve cover breather that has a check valve disk. I removed my Whipple to install larger injectors and the supercharger was pretty clean inside after 11k miles.
2016 NFG 1SS A8
04-30-2022, 09:30 AM | #4 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
I’m installing an E2-X as we speak. It’s a well made piece.
Kong Stage X Port, NW103, LPE HPFP, XDI +30 Injectors, ARH Headers, Flex Fuel, JMS Booster, AWE Touring, Elite E2-X CC. Stock heads, stock cam, stock pulleys: Tuned by KingLT1. 740whp Uncorrected on e50
04-30-2022, 09:54 AM | #5 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
I run the E2-X Ultra and love it no problem with and it catches oil.
04-30-2022, 10:07 AM | #6 |
04-30-2022, 11:25 AM | #7 |
04-30-2022, 11:49 AM | #8 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
Que Elite to come in here and give their whole spiel on why theirs is the best.
04-30-2022, 12:39 PM | #9 |
Thank you Al Oppenheiser!
04-30-2022, 01:50 PM | #10 |
Reasons why this video doesn't jive with my own testing results. I had my Mighty Mouse Wild on my car for 3k miles before I pulled the blower lid and checked mine, there were no pools of oil residue in my blower anywhere, and this is on a 700whp ZL1, it was pretty much bone dry as far as I could tell.
04-30-2022, 06:18 PM | #11 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
Exactly. And if you install their catch can, there will be riches waiting for you at the end of a rainbow.
04-30-2022, 07:14 PM | #12 |
Wait …. They told me i would get 72 virgins aT the end of the rainbow.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
04-30-2022, 07:41 PM | #13 | |
I'm not affiliated with either company, and received no compensation from the company. I did purchase both catch cans, and was surprised at the results. I did contemplate for quite a while about even posting it, as I don't want to make anyone look bad, but the results are what they are. You are lucky if you are filtering that well, but I suspect most likely you are just venting everything out, factory vehicles will never produce the pressures that your 700whp produces, and thus will rarely vent, so they will be forced to recirculate the air and filter as best they can.
04-30-2022, 07:41 PM | #14 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
catch can, elite engineering catch can, mightymouse |
