02-10-2019, 08:07 AM | #1 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Who is leaving the ZL1 add-ons lift blocks on
After owning them for nearly two years I just installed them this morning as I'm having my tires replaced. Curious if everyone is leaving them installed or removing them after each use.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
02-10-2019, 08:28 AM | #2 |
Drives: 16 2SS Convertable Join Date: Feb 2018
Have to take mine off after each use, lowered the car, lol
2SS Convertible A8, NPP, GMPP CAI, Flow tie grill, Mishimoto Oil catch can, Eibach lowering springs.
02-10-2019, 08:58 AM | #3 | |
Thank you Al Oppenheiser!
Installed mine at ~750mi, and am now ~5700mi after 18 mos with no issues with the car up in the air 4 or 5 times. One screw on one of mine needed to be tightened after a month. They have been rock solid since. Some folks have used blue loctite, others swap to longer set screws, or both. If you're like most folks who probably just do nothing then check them and tighten if necessary after your first drive, and then again after a month or two. |
02-10-2019, 09:04 AM | #4 |
Drives: '18 Camaro SS Redline, '20 Bolt EV Join Date: Jul 2018
I left mine on with a little blue loctite.
Also switched to standard hex head screws. So much easier to deal with than the set screws. |
02-10-2019, 09:11 AM | #5 |
Drives: 2016 Camaro 2SS Join Date: Apr 2017
I left mine on too...with locktite. No issues.
2016 2SS, MRC, NPP, A8. Procharger P-1X,Stage II,std bypass, 3.9, Alky Meth - 10.84 @129 - DA+2000
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth. |
02-10-2019, 09:33 AM | #6 |
Thanks for the replies. I will leave them on and next time I'm under there I will add some loctite.
02-10-2019, 09:42 AM | #7 |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
What type of screws do they come with, anyone know what size. Thx.
02-10-2019, 09:58 AM | #8 |
02-10-2019, 10:12 AM | #9 | |
If you want to upgrade to 3/4" long, try these: https://www.ebay.com/itm/33110389941...&s=ci&mail=sys |
02-10-2019, 10:30 AM | #10 |
Drives: 6th Gen NicKey Camaro & others. Join Date: Nov 2015
Leave mine on as well.
02-10-2019, 10:36 AM | #11 | |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
02-10-2019, 10:42 AM | #12 |
02-10-2019, 12:43 PM | #13 |
Drives: No Camaro :( Join Date: Apr 2013
Good post and info. I’ll be ordering me some whatchmacallem’s and thingamabobs to secure them soon. |
02-10-2019, 12:50 PM | #14 |
Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
On the car, daily drive, 15000 miles...
Not loose, checked them 2-3 times when the car is up for fluid change Didn’t Move or unscrew... |
