02-10-2019, 04:46 PM | #15 |
Drives: '17 2SS H50 Join Date: Mar 2016
Blue loctite, been on for months.
2017 H50-2SS-MN6-F55-NPP-RIK-WL4-IO6
1100 - 5/26 0000 - Cancelled - 7/5 Contacted Becky - 7/1 2000 - 7/5 3000 - 7/6 3000 - 7/11 TPW 8/1 3100 - 7/18 TPW 8/1 3300 - 7/20 3400 - 7/21 Built - 8/2 - PS 1,182/1 of 699US 4300 - 8/3 5000 - 8/5 6000 - 8/13 |
02-10-2019, 07:58 PM | #16 |
Drives: 2018 ZL1 Hyper Blue A10 Join Date: Jan 2018
02-10-2019, 08:33 PM | #17 |
Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
Left mine on, with blue loc-tite
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
02-11-2019, 02:13 AM | #18 |
Drives: 2017 2SS M6 Join Date: Jun 2013
9500 miles mine are still on with blue loctite
02-11-2019, 08:31 AM | #19 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
I lost 1 the same day i installed. But I'm sure it was my fault from not tightening properly. Blue loctite never crossed my mind, nor replacing the proved bolts which was kind uncomfortable to tighten with the little tool they provided. All other 3 have held on for a year already.
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
02-11-2019, 09:15 AM | #20 |
Drives: Traded in 2016 BLUE VELVET 2LT RS Join Date: Aug 2016
I have had mine on from since I installed them in Early 2017(15000 miles now), no issues. I guess I will check and see it they are loose the next oil change.
02-11-2019, 09:26 AM | #21 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
Mine is still on after a year. No blue loctite. Just made sure that i tighten them down like crazy. I'll probably go back through with blue loctite.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
02-12-2019, 01:23 AM | #22 |
Drives: 18 Camaro 2SS, 07 Saturn Ion Join Date: Apr 2018
I was thinking the same thing. I tightened the heck out of them but I probably should throw some loctite in there too just to be sure.
Ordered from Becky D __ 2018 2SS Silver Ice Redline 6MN, NPP, MRC, GM CAI
02-12-2019, 02:27 AM | #23 |
Here is my personal experience on this, Yes, it is true these things become loose overtime! I was about to lose one of those lift pads but the other screw kept it holding nicely so I was lucky and took sometime to invest on those pads to realize where I went wrong. others on the forum were not lucky as seen from the comments on the topic and I don't blame you. I installed the lift pads on the end of May 2018 for those wondering how much it held up.
I have a few tips to share based on my experience: 1- Always keep the allan key in your glove box it is vital that you do it anything can happen keep it for emergency sake! 2- When you will install those pads they are actually installed incorrectly? Now you're gonna ask why or tell me that I'm crazy? The lift pads need to cover the entire pinch weld even the top part of it with no gaps or spaces (To simplify the top part of the lift pad which is the flat surface needs to be perfectly aligned towards the roof of the pinch weld which is on top of the pinch weld leaving no airspace on top) so how to do that? You will need to regularly install those lift pads at first per the product instructions. Tighten everything hard as you can so they don't fall off while driving, when the car is being lifted by service on the lift the bolts will somewhat get a bit loose this is normal again due to pressure, the pads will automatically adjust due to the force being implied on the lift pads by the car lift so the bolts are still holding on nicely. After your car is being serviced, retighten all the bolts properly you will notice that those gaps are gone. Explanation:The Pressure by the lift when the car is lifted allows that adjustment on all 4 sides since the top of the lift pad will stick to the roof leaving no gaps 3- Regularly check the lift points after each service by re-tightening the 8 bolts, there is no point of having a blue loctite on those they are not meant to have those, pressure needs to be distributed evenly at first by lift then retighten wherever necessary. I wouldn't recommend anyone to use blue loctite the idea isn't locking at first its adjustment then locking. |
02-12-2019, 06:04 AM | #24 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
let mine on as well they survived a trip to Camaro Fest
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
