05-03-2018, 08:50 AM | #1 |
Drives: 2011 Camaro SS Join Date: Sep 2017
Door panel swap
Good Morning,
I recently purchased 2015 door panels with the summit white panels for my 2011 summit white SS. The 2015 has the door lock/unlock on the door panel now, has anyone swapped from the 2010-13 door panel to a 2014-2015 panel. I was wondering if I need to swap the white panels over to my doors or can I just use the 2015 panel. |
05-03-2018, 05:09 PM | #2 |
Drives: 2010 1SS RS M6 Join Date: Jan 2015
I just did the insert swap a few weeks ago. Pretty easy, took less than an hour. Sharp razor blade to cut the plastic heads off the rivets, some short screws to reinstall. I would think you’d need a wire harness to add the door lock switch .if you want to just switched the entire door panel
Vararam intake, gmpp exhaust, borla stainless long tubes, cat less, jannetty tune, bmr lowering springs, heritage grill , smoked lenses
05-03-2018, 06:18 PM | #3 | |
Thank you for the reply. |
