10-10-2022, 10:27 PM | #1 |
I’m Magik a physco dog
Drives: '15 1LT/RS & '23 3LT/RS Join Date: May 2016
Pitted Headlight lenses
Anyone do a repair to remove the pitting ( not yellowing) on the lenses, I’ve heard about a sanding process but that concerns me it may cause additional damage to the lenses, any tips or suggestions?
TIA.
2023 3LT RS Shadow Gray
2015 1LT R/S Blue Velvet Coupe. Previous: 2015 1LT Ashen Grey 2016 1LT Blue Velvet My entire life has been 'A Midlife Crisis' |
10-11-2022, 02:22 PM | #2 |
Drives: 2011 Camaro SS/RS M6 Join Date: Oct 2010
Can you post some pics?
10-11-2022, 02:26 PM | #3 |
10-11-2022, 07:36 PM | #4 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Most reputable detail shops should be able to take care of them.
10-19-2022, 06:13 PM | #5 |
Hey guys thanks for the reply's and link and here are a couple pics, you can only see it when headlights are illuminating the lens from behind.
At first i thought it was water spots so cleaned them up but still there.
10-20-2022, 09:18 AM | #6 |
I have the same,i've let them be.
10-20-2022, 07:21 PM | #7 |
Me too, mine are like that.
10-21-2022, 12:37 AM | #8 |
I've used the 3M headlight resto kit i got the pass side done and will do the drivers side next.
A quick review it was super easy and the results are great I'll post pics when I'm finished. Now that the lens is clear I've also noticed a separate issue on the pass side, some metallic speckling on the inside of the housing maybe off the halos??? IDK
10-26-2022, 02:30 PM | #9 |
So after a couple days of rain I was finally able to finish up, i did add a step of 1500 & 2000 grit (I had in my arsenal)before the included 3000, I wish they included two of the 3000 grit Trizact discs it’s hard to tell when it’s used up and would have been nice to dedicate I disc to each HL.
Also I didn’t use the first step of the 500 grit after testing a small spot I thought that would be better for lenses that were hazy yellow and thought the sand marks were a little to aggressive so I started with 800. Using the included rubbing compound I did follow up with a couple passes of polishing compound just for good measure, lol Overall a big improvement,those whitish pit marks are gone, I’m happy and it was a approximate $25 fix.
10-26-2022, 09:09 PM | #10 |
Drives: Chevrolet Camaro SS Join Date: Jul 2021
10-26-2022, 11:38 PM | #11 | |
Mine were not and now the beam is not distorted and is much clearer/ brighter, it’s a little disturbing when it’s all sanded and hazy looking like I just ruined my lights but then as you go thru the steps it’s like magic lol. good luck with it just take your time.
10-29-2022, 08:41 PM | #12 | |
11-08-2022, 10:04 AM | #13 |
Drives: 2010 Camaro 2SS Join Date: Sep 2015
I did mine the last time I had the bumper cover off however I did not use any spray coating. The Camaro's headlights are recessed and fading or yellowing has never been an issue, just the pitting.I performed all the sanding steps then a wet sand and then polished with a round ball foam pad attached to drill that was meant for rim polishing. It worked very well, just the right size for the headlights. I think the spray coating would be ok for different vehicles but we don't need it besides I think orange peel is unavoidable and you'll be sanding it off again to fix it.Maybe a clear vinyl would be better to protect from pitting as a last step would be better.
11-22-2022, 09:44 AM | #14 |
Sanding followed by SprayMax 2K headlight clear followed by polishing with Meguiars compound.
