Old 04-02-2020, 10:15 PM   #1
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
LSA conversion pulley size
Hey guys, I putting together an LSA swap kit. I am going through Boost District. In your guys experiences what is the smallest pulley you can run before belt slip? Goal is mid 600's. Thanks for the help.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 04-03-2020, 01:21 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
Griptec pulley will help. Any of them can slip so Griptec is the way to go
747 RWHP 794 RWTQ
Old 04-04-2020, 12:37 AM   #3
Athletics101
Drives: 5th Gen L99
Thanks for the response Hammond. That’s the pulley brand they sell! So that’s good news. What size pulley are you running?
Old 04-05-2020, 07:12 AM   #4
LaN-
Drives: 2014 SS Convertible
I’m at 628 rwhp with the stock pulley.
Engine: LSA Conversion, Ported Heads, 1 7/8 headers, VMS 2.5 Cam, Roto Fab intake, ADM Scoop. BMR engine mounts, 3.91
628/525
Suspension: Koni orange, (BMR everything) 1" drop springs, toe rods, trailer arms, non adjustable LCR, FE4 sway bars, sub frame connectors, delrin sub frame bushing and upper control arm bushings. Front bushings.
LaN- is offline   Reply With Quote
Old 04-05-2020, 02:56 PM   #5
hammdo
hammdo's Avatar
2.45 and a 9.17 lower
-Don
747 RWHP 794 RWTQ
Old 04-05-2020, 07:05 PM   #6
Vegas Bound
Drives: 2013 Sparkly Red One
2.55/9.5 8 rib no slip.
