05-30-2020, 07:54 AM | #1 |
Drives: 2010 camaro 2SS/RS M6 Join Date: Sep 2014
BTR vs CHE Trunnion upgrade
BTR uses an upgraded needle bearing design over stock and CHE uses a bushing design.
It seems going to a bushing would be a step in the wrong direction Am I missing something here?
Texas speed F-35 cam, rollmaster timing set, melling hp pump, ls2 chain damper, fluid damper 25% under drive, Che rocker bushings, tsp .660 lift valve springs, BBK CAI Amzoil filter with Phastek ww relocation and scoop, Gmpp axle back, Speed engineering 1 7/8" LT's no cats, Peak speed shop ported tb, NGK tr6, MSD wires, Amsoil Zrod wix, heritage grill, 1.25" BMR springs, MRR 228, Nitto Nt05,dyno tuned by complete street performance, elite eng catch can, clean side separator, Hurst shifter, Zl1 addon wickerbill
05-30-2020, 08:00 AM | #2 |
Just realized TSP’s kit is also a roller bearing design and it’s cheaper than CHE
05-30-2020, 11:25 AM | #3 |
I haven't seen much for long term tests on the CHE but the bushings have grooves in them for oil so the idea is they float on the oil film. It's better than needle bearing riding on the trunion. The btr v2 is good because they use an inner race for the needle bearing to ride on and they are held in by clips rather than pressed into the rocker i believe. Comp uses clips but no inner race so the needle bearings wear into the trunion.
05-30-2020, 01:51 PM | #4 |
Do a search, plenty of unhappy people that have used the various needle bearing upgrades available.
These Straub Technologies bushings I used work great. The wear is extremely minimal due to the fact the spring pressure is spread out over a much larger surface than the many minimal points of contact with needles. Just the fact there are no needles to go wandering through the engine is a huge plus !
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be |
05-30-2020, 02:12 PM | #5 |
Drives: 2015 1LE Join Date: Oct 2015
I have not used the bushings but I have the BTR kit in my car with 12,000 miles on them with no issues. Although its needle bearings, they are captured and can never work loose like the factory ones.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
05-30-2020, 03:03 PM | #6 |
I understand that the factory ones have the potential of letting the bearings float thru the engine. Nobody wants that, but if you contain them with an upgraded kit like the BTR v2 it just seems odd to me that anyone would want to take a roller bearing out and replace it with a bushing. I’m not a high performance engine builder and maybe their is some science to it that I don’t understand
I think upgrading to a high performance oil pump would be a must to keep them oiled at all times
05-30-2020, 11:34 PM | #7 |
Drives: 2014 2SS/RS Join Date: Jan 2018
I have the TSP ones. I have about 12k on them now. I plan on pulling the covers and checking everything out .
When I did my cam swap, I pulled my covers to find two of my oem rocker trunions were trashed. Had three out of four bearing assemblies completely obliterated and needle bearings everywhere. Even had two halves of bearing races in the lifter trays. Car ran like a champ. The oem design is bad.
2014 2SS/RS LS3/M6
05-31-2020, 06:47 AM | #8 |
Thats not good... luckily it doesn’t sound like they cause any damage. Your car is a ‘14 so now I’m wondering what I might find. I beat on it pretty good at times
Let me know what they look like when you pull a cover
05-31-2020, 08:32 AM | #9 | |
One guy said it best. on the internet good news travels slow and bad news is instant. The needle bearing issues may be corrected with the new kits running on a inner race that’s pressed onto the trunion. This is the way I am leaning although the reports of a much quieter valve train and no needles with the bushing kit is something to consider
05-31-2020, 09:08 PM | #10 |
Drives: 2014 1ss camaro Join Date: Jul 2017
I would also like to hear from long term bushing users.
05-31-2020, 09:26 PM | #11 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
CHE in mine for 1 yr and 15k miles. No issues so far.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
05-31-2020, 11:11 PM | #12 |
As for longevity, I have no idea. I also went with them to avoid any issues with dealing with needle bearings in the future. I have searched and have not found anything bad about them yet.
Only 2500 miles on my CHE's so far. I figured the cost was worth it as they are highly regarded in the industry and for ease of install. The CHE bushings do not get pressed in as they are precision fit. Lube em up, pop them in, and set your snap rings. I actually enjoyed doing mine. I had also considered the Straub and Smith Bros., but lots of people claim CHE is at the top of the list for quality, so I went with them.
05-31-2020, 11:29 PM | #13 |
There is. TSB from GM about it. It happens in all LS based engines. Even the trucks.
2014 2SS/RS LS3/M6
06-01-2020, 06:32 AM | #14 |
Drives: 2014 SS Convertible Join Date: Jun 2015
Having picked out needle bearings from my oil pan I would recommend bushings.
Engine: LSA Conversion, Ported Heads, 1 7/8 headers, VMS 2.5 Cam, Roto Fab intake, ADM Scoop. BMR engine mounts, 3.91
628/525 Suspension: Koni orange, (BMR everything) 1" drop springs, toe rods, trailer arms, non adjustable LCR, FE4 sway bars, sub frame connectors, delrin sub frame bushing and upper control arm bushings. Front bushings. |
