04-16-2020, 08:33 PM | #15 | |
Have you just been looking here in the forum? I’m assuming probably FB/eBay etc. also. |
04-16-2020, 09:35 PM | #16 | |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
04-16-2020, 09:36 PM | #17 |
Valkyrie14
When you did your LSA who did you use to do your tune?
04-16-2020, 10:59 PM | #18 |
'It's an experiment'
If you ck my build thread, I wrote the install guide for ADM and did ALL kinda of mods ;o). Guide is linked in the first post...
GPI did my first tunes, after that, ABADZL1 and I did them... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
04-17-2020, 07:25 AM | #19 | |
Valkyrie14
For tuning do you use HP? I have an SCT, but I have been wanting to be more hands on with my own tuning. But that was when I was thinking of tuning for basic bolt ons. A blower and cam down the road seem daunting to me and I am just pay for the tune. My challenge is that there isn’t a tuner with a dyno within 3 hours of me.
04-17-2020, 07:28 AM | #20 | |
Valkyrie14
I was going to roll with stock, but if I have to take it apart to change I think I better do this now.
04-17-2020, 09:20 AM | #21 | |
Drives: 2014 SS Convertible Join Date: Jun 2015
Although the boost level itself is ultimately a result of the efficiency of the motor the pulleys determine how fast the blower spins which results in how much air it moves. The more air it moves the more boost it will create. That being said you can change either the crank pulley or the supercharger pulley to change the boost level. It easiest to change the supercharger pulley. To give you more reference.......I'm on the stock crank pulley and stock supercharger pulley. I'm seeing 5-6PSI with that setup. If i didn't have ported heads or an NA cam I'd more than likely see a higher number, but all that matters is the power to the ground not what my boost gauge says. The stock pulley is roughly 3" so get 2 piece pulley around 2.75"-3". This way when you want more power in the future its a simple swap of the supercharger pulley and a shorter belt.....and a tune lol.
Engine: LSA Conversion, Ported Heads, 1 7/8 headers, VMS 2.5 Cam, Roto Fab intake, ADM Scoop. BMR engine mounts, 3.91
628/525 Suspension: Koni orange, (BMR everything) 1" drop springs, toe rods, trailer arms, non adjustable LCR, FE4 sway bars, sub frame connectors, delrin sub frame bushing and upper control arm bushings. Front bushings. |
04-17-2020, 10:15 AM | #22 | |
Mark (ABADZL1) and I use my laptop in my car, Mobile WiFi on my phone, and I go driving While we’re talking and he works my laptop remotely. TeamViewer is what we use so he can remotely control my laptop. Works pretty well I might add ;o) I know there is a lot in my thread but, I do go over tuning and what we did for e85 also.. -Don
747 RWHP 794 RWTQ
04-17-2020, 10:39 AM | #23 | |
For example there's an import shop right down the street from me and I rented their dyno before the blower install to get a reference point and once the weather gets nicer i'll go back to get the after numbers. $50 for a few runs isn't much to have that data.
04-17-2020, 03:40 PM | #24 | |
Valkyrie14
I like the idea of the remote tuning on the laptop while driving with my tuner doing a live reading. Does Mark teach you about what he is doing and why?
04-17-2020, 03:42 PM | #25 | |
Valkyrie14
04-17-2020, 03:52 PM | #26 | |
Valkyrie14
04-17-2020, 05:16 PM | #27 |
Ted at Jannetty knows the cars like the bank of his hand. When I did my whipple he sent me a tune to get me running and it was 98% perfect I had no complaints, he just got a little more power out when I dynotuned. He'll also remote tune using data logging. Elesthree on here just used his time to get his she pushing over 900whp and fixed some of his issues. He can do a lot. As far as boost, your pulleys are like the gears on an 18 speed bike and the blower is the rear tire. Boost is the measure of restriction. So before my cam my 3.875" blower pulley got me 10.5psi, after the cam same pulley size I dropped to 8psi, because the engine is less restrictive and can breath better, though i'm still making more power. So I have to drop my pulley size to get my boost back, and it will make even more power! I don't know the lsa pulley size set ups, but Ted uses sct and if you want to pay him to do your running he will get you where you want to be.
04-17-2020, 06:18 PM | #28 |
Valkyrie14
I PMd Ted and Mark, Let me know any other tuners that are experienced at this conversion and I will talk to them as well. I underestimated what the tune is going to cost.
Pulleys. 8 rib or 6 rib. We are running up against the edge of my budget. I got the lower today and there wasn’t a pulley on it. So I need to get one of those. Budget wise I think I need to use as much of the LS3 pulleys that I can to save money at this point. What mods are necessary, any spacers that are needed. I see some spacers in kits, but some of those are for L99 kits, and I don’t know the minor differences between the engines, if any. I believe the stock is 6 rib. So can I get a 6 rib pulley and belt and be done with that part of the project or is there a need to replace the crank pulley? At this point I could delay the project if going to an 8 belt is worth it and get the additional parts. What is the benefit of 8 rib and what would I have to also replace? Getting there. Biggest pieces are either here or on the way. Thanks for all of the advice so far and advice to come. This forum is great.
