Old 11-09-2020, 09:57 PM   #1
clg82
Drives: 2020 Camaro ZL1
Best lights for garage....
Hey everyone looking to add some lights to brighten up my garage. All I currently have is the garage door opener light and would like to add some hanging lights and wanted to know what everyone’s suggestions are. Thanks for any help!
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21
clg82 is offline   Reply With Quote
Old 11-09-2020, 10:18 PM   #2
h422694
h422694's Avatar
Go to Home Depot, Lowes, Menards and get some 3-4 ft Integrated LED Strip Light. Bright, cheap, 29.95, no bulbs to break, last forever, can be chained together or separate pulls. I have them in garage, basement, re-loading area, etc. Take one home and try it. If you don't like it, return it.
h422694 is offline   Reply With Quote
Old 11-09-2020, 10:33 PM   #3
Rnovrit
Rnovrit's Avatar
Drives: 2018 NFG ZL1-1LE
I went with a bunch of 6” can lights with high wattage LED bulbs. 44 lights to be exact. This is while it was still under construction.
Rnovrit is offline   Reply With Quote
Old 11-09-2020, 10:54 PM   #4
Vegas Bound
Drives: 2013 Sparkly Red One
Amazon Leonlite 40w LED lights. I have 4 in my garage and it is like daytime. 4 pack is less than $100. Easy install.
Old 11-10-2020, 12:47 PM   #5
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
I got these ones. They are really easy to install. You can daisy chain them together too.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 11-10-2020, 02:45 PM   #6
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
This is what I went with, easy to install, picked up a few at a time and lined the perimeter of the ceiling.
'18 1SS 1LE Black, PDR
Old 11-10-2020, 02:51 PM   #7
MANNAXMAN
MANNAXMAN's Avatar
Drives: 2016 Camaro 2SS Convertible
Make sure to check the light color temperature. You want something in the 4000k-5000k range to simulate daylight. Anything lower and you're going to have yellowish lights.
2016 Camaro 2SS, Convertible, Summit White, A8, NPP, NAV, Daily Driver (Sept. 2016-Present)
1996 Camaro Z28 with T-Tops (Sold 10.22.16)
1986 Camaro IROC-Z with T-Tops (Sold)
1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present)
1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold)
Follow me on Instagram - @gen6_2ss_vert
MANNAXMAN is offline   Reply With Quote
Old 11-10-2020, 04:46 PM   #8
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
These lights are super bright.
https://www.amazon.com/Four-Leaf-Def...dDbGljaz10cnVl
Camaro2ss2010 is offline   Reply With Quote
Old 11-10-2020, 07:37 PM   #9
clg82
I ended up going with these, hope I like them. Any pictures of them on by chance zlathim?
